Greg7579
The other long battery thread is getting clogged, and I responded too many times so the message gets garbled. Here is a new thread with a good example of what I have been talking about.
Here is my travel (and home) setup. I use one 100-watt Baseus desktop charger (soon to be a 240-watt Anker latest model charger). It has a power cable so you can place the charger far from the wall plug, like on top of a desk (as pictured here on my kitchen counter). It has two USB C ports and two USB A ports. One of the USB A ports is optimal for QC charging if you have a device with an older QC version that is not interchangeable with PD. All ports are PD-capable and will handshake with all ports to over 34 various combinations of Volts-Watts-Amps so you can charge anything that is PD capable up to 100 watts, whether it is a laptop, phone, tablet or tiny low power devices like ear buds or watches.
The battery charging bases I use for my camera batteries are Nitecore. The Nitecore bases are designed for almost all popular camera models, and they have LED readouts and the latest tech. These mounts must be connected to a charging device as they are just powerless mounts. The latest Nitecore chargers are all USB C, but the older models that are USB A are fine. In the example here, I can put a USB C adapter on the USB A plug and switch from the USB A port to the USB C port and the charge is the same.
Here I have two GFX 100S Wasabi batteries charging on the Nitecore mount. (Note: I also own 3 Fuji batteries for my 100s, so don't get mad at me for using Wasabi and Watson for all of you batter judgers and ideologues.) I have two Fuji GFX 50r batteries charging on the Nitecore mount. There is a Leica Q2 battery charging on its Nitecore mount.
So, here there are 5 batteries from three different cameras all fast charging at once on the same charger on three different Nitecore mounts. The LCD readouts on the Nitecore mounts show the battery charging temps, voltage and amps for both the current maximum charging rate - how much has been provided as well as how much remains to be provided. It also lets you know if the battery is healthy. It also tells you if the battery is fast charging or not. I have noticed that as the battery gets fuller, sometimes it stops fast charging. It will also stop fast charging if the temp gets too high.
The optimal charging rate is negotiated between the battery and the charger, and it reads out on the Nitecore mount. You can't overcharge a battery, so you can plug the 100-watt laptop into the same connection as a very low-watt watch - as long as the device has PD it will do the proper handshake.
Note: the Leica Q2 charger is Nitecore's worse charger because it has a built in 3-inch USB A cord that will just dangle off of a wall charger, but on my desktop charger, it doesn't matter.
Don't pay too much attention to the readings. I had just plugged all three of these mounts in and the batteries were already charged. Plus, the readout switches between several types of readouts.
These LCD readouts are reason enough to trash all your OEM chargers. LOL.....
Greg Johnson, San Antonio, Texas
https://www.flickr.com/photos/139148982@N02/albums
