David Bostock
Active member
I've really struggled with C1. I really like the software, the workflow, and the color balance. What I can't seem to deal with though is the loss of detail in the image. I'll call it image definition. Take a look at the examples...These are full size crops from a raw 10D image.
The first one was done using BreezeBrowser, no sharpening applied
The second one is with C1, As shot settings with Sharpening disabled in preferences, and noise reduction at low.
I tried to get them as close as possible, I know the color is a bit more robust in the C1 image. But aside from the color, do you see the difference in the leaves, the brush, and the tree trunk? I think it's that plastic look people have been describing. I've tried all different settings with C1 and had zero luck improving the image. The BB image is soft, but the detail in the leaves is clearly there.
For those who want to play around, here's a link to a ZIP file that contains the RAW file, full size JPGs of the C1 & BB versions and these two crops:
http://davidbostock.com/files/BBvC1.zip
Let me know what you all think. I'd like to use C1, but not with this look.
db
db
