Norberto Arquilevich
Forum Enthusiast
How good does the c-750 do in interior low light conditions?
--How good does the c-750 do in interior low light conditions?
1.6 sec
13 sec
16 sec
seem like there are too much noise at 2nd/3rd shots ... Does anyone
know C-750 has noise reduction ?
feel free to comment my shots at
http://www.pbase.com/maxaserver/
I haven't done a lot of night shots, but there does seem to be too many stars in that night sky. Are you sure that last shot was 16 sec? I can't believe the people in it would have been still for 16 sec and that nothing in the picture showes any sign of movement. Am I missing something?here are some of my nite shots taken with C-750
--... and only kicks in for long exposures (not sure of the exact
value but I think it is 1sec and above).
atwl
http://www.imageevent.com/atwl77
'Weesa da Gungans. Resistance is futile. Yousa be assimilated!'
Sony D S C - U 2 0
Oly C 7 4 0 U Z
Oly C 7 5 0 U Z
If you get "stuck", "bad", or "dead" pixels you should run pixel mapping.Alf B.,
Thanks for the tip. I will continue to do more test before I return
this cam. btw , what is pixel mapping ? when should I run it ?
--If you get "stuck", "bad", or "dead" pixels you should run pixelAlf B.,
mapping.
I have the C-730 and a couple of days ago I discovered at least one
dead pixel. I had never used pixel mapping so I thought I would
try it.......It worked!
If your C-750 has the same menu setup as the C-730, you should find
it by setting the camera to A/S/M then press the "OK" button then
"mode menu" to bring up the menu index.
Scroll down to "set" (setup) then press the right arrow then scroll
down to "pixel mapping", again press the right arrow and it should
say "start".
Press the "OK" button and wait until its finished. It should only
take a few seconds, then press the "OK" button to exit the menu's
and try taking a few test pics.
The dots should now be gone!
This does not damage the camera in any way and you can do this as
many times as you need, should anymore dots, or "dead pixels"
appear in the future.
In the very unlikely event it does not work then yes, you should
return your camera and swap for another.
Alf B.
