Sure, I have seen it. Same thing at ISO 100. The best way to
reduce it or eliminate it is to underexpose by a stop plus. SPP
will accomodate accordingly.
The sure way to tell that you will have to do additional WB
adjustments is to watch the image load in SPP under raw. If after
the initial processing is completed you get a noticiable color
shift, than 1st try using a different WB setting and see if it gets
close to what it's suppose to be. If that does not work then adjust
with the color wheel or in PS.
Two areas I have noticed this.
1) Highly saturated reds - strong shift to pink or yellow in blown
out areas and pink in adjacent areas. Best correction is
underexpose but -0.7 to -1.3.
2) In scenes dominated by redish cast light (usually in evening,
but not always) raw processed image turns from proper looking
exposure to a strong yellow cast. You will see it change in SPP
after processing as a raw file. Best correction that works for me
is to make your normal SPP adjustments except for the color wheel
adjustments. Save and make corrections ove in PS. I have a action
that I put together that works for about 80-90 percent of those
type of files. If you don't want to go through that hassle then
establish a custom WB for that shooting condition.
Every digital camera has it little quirks. The true artist learns
to use the positive and negatives of the camera to their advantage.
You will find a number of shots in my galleries that had the above
mentioned quirks and were corrected easily once I figured out the
problem.
In particular look in
http://www.pbase.com/mjmorrison/zion_national_park
and
http://www.pbase.com/mjmorrison/sd10
Mike
Today I have made some shots at iso200. Generally not bad, but the
white balance is wrong in the most of shots.
And, the main trouble, I have shot an red car - the car is not red
at the shots!
the left image is unedited, the right image edited in the photoshop.
Image -> Adjustments -> Selective color -> Megnetas:
Magneta -50%
Yellow +50%
Anyone has the same effect?
ps. I don't know the effect on the iso100, because does not shot at
iso100 this time.
If you found any errors in my english - please let me know.
http://www.pbase.com/crea7or/
http://crea70r.photosight.ru/
http://www.pbase.com/sigmasd9/user_sd10
