Jackpot101
Active member
- Messages
- 89
- Reaction score
- 70
Does anyone have a strong opinion on how they like their backpack with tripod organised?
Personally, I’ve always preferred a side-loaded setup. It keeps the tripod closer to the body, which is especially helpful when navigating tight spaces — I can easily reach behind to check that it’s not snagging on anything. With a center-mounted tripod, I can't reach it as easily, and it tends to pull the bag forward, constantly shifting the balance. It also feels more bouncy, since the weight exaggerates the movement at the front of the pack.
Another advantage of a side-loaded tripod is when you're in muddy conditions. You can lay the bag down with the bag front facing down (in the mud, sand......), strap in the tripod from the side, and then lift the bag straight up without exposing the bag's back and straps to the mud. With a center-mounted tripod, you usually have to flip the bag face-up to access the tripod straps — which means setting the camera back and shoulder straps directly into the mud.
Front loading.
Side loaded
Front loading.
Side loaded
