Since I have decided to create a blog post at SigmaPhotoPro.com about advanced B&W processing in SPP 6.6.1, this forum seemed like a good place to start a thread discussing the latest processing techniques. I'm hoping I can "enhance" my post using what I learn in this thread.
Today and yesterday I processed some photos and uploaded a bunch of jpegs to a gallery at my website here: https://www.bigprintphotos.com/SDQH-vs-SD1M
In that gallery you will find downloadable files, exported from SPP 6.6.1 as level 12 quality jpegs, along with many screen shots that show the settings I used in the Monochrome tab. Here is a series of those screen shots, showing red, green, and blue at 100% on the color wheel, for both SD1M and SDQH raw files:
SD1M set to 100% red on the color wheel
SD1M set to 100% green on the color wheel
SD1M set to 100% blue on the color wheel
SDQH set to 100% red on the color wheel
SDQH set to 100% green on the color wheel
SDQH set to 100% blue on the color wheel
As you can tell by the settings, I did my best to recover the highlights, which meant major adjustments. These images are therefore just examples of hypothetical settings, and not examples of finished photos. I would not normally make a final photo so dark. I just wanted to see what it would take to recover the images. They are also not the best examples of a comparison of highlight recovery capabilities, because the light was changing, because of cloud cover, so the exposure from the SD1 Merrill received either more or less light than the one made with the SD Quattro H, even though the shutter speed and aperture were the same.
You'll also see that I shot these two photos at ISO 100. Comparing SD1 Merrill and SD Quattro H files shot only at ISO 100 is not really fair, because there could be an advantage that one camera has at a higher ISO setting, so this "test" is not supposed to be some exhaustive comparison. It is something that people can use to "get a feel" for what can be done with the two cameras using the Monochrome tab in SPP 6.6.1 though.
Here is an example of processing using 100% green with a shot of a garage from the SD Quattro H:
SD Quattro H processed with 100% green in Color Mixer
I "recovered the highlights from the light as much as possible" here, and since I like contrasty and detailed B&W shots I set the Detail adjustment to the most Crispy setting. I did use X3F Fill Light and Shadow adjustment too, but only lightly. As you can imagine, using 100% blue with this image made the reddish brown doors much darker, which I didn't like. Using 100% red made them lighter, but I like this use of the green channel best, I think. Here is a full color version of this image for reference:
SD Quattro H - 4 seconds at f5.6 and ISO 100
Hopefully we'll have some good discussion about B&W processing in SPP from various visitors to this forum here in this thread.
The raw files for these two photos you see above in the screen captures are available at the bottom of the blog post here:
https://sigmaphotopro.com/advanced-bw-processing-in-spp-6-6-1/
EDIT: This morning I shot a brightly lit house, and when processing the Quattro file I discovered something - the Detail tool affects highlight recovery. Here is a pair of screen shots that show it:
As you can see by the red overexposure indicators, changing the Detail setting from Smooth to Crispy has blown some parts of the image. It's easy to fix, but it's something to keep in mind for certain situations, where a file is very close to being blown. A possible last ditch highlight recovery method might include setting Detail to Smooth.
This will not, of course, work with a Merrill raw file, because the Detail tool is only available for Quattro files.
Scott Barton Kennelly
http://www.bigprintphotos.com
