I just turn it off. If I were a jpeg shooter, I'd probably use it.Do you turn on Active D lighting, or just correct on post processing?
I have a Z8 and use DXO PL8.7 in post.
For raw files the only thing Active D-Lighting does is underexpose them (minimum 1/3 stop at lowest level, as high as two stops at the highest level). This means you'll be bringing shadow detail up and promote noise in raw processing.I often have ADL set to "normal" and shoot RAW only.
In terms of actual exposure..trueFor raw files the only thing Active D-Lighting does is underexpose them (minimum 1/3 stop at lowest level, as high as two stops at the highest level).I often have ADL set to "normal" and shoot RAW only.
Not necessarily...if you are using Nikon software for initial processing...Shooting with ADL on (and Matrix metering) can give you a head start in PP for the final optimal look you're trying to present (get me the starting optimal data for my workflow/intent). For me, ADL on when shooting RAW saves me a lot of time in my PP workflow. It usually results in the exposure solution I would have used anyways had ADL been set to off. That's especially true when I'm bracketing with it, in my experience. In some cases...best to keep it off...like with flash as I have noted. Also, I turn it off for center and spot metering. Like any tool in the tool box...use it a lot and it can be a plus with experience...but not always the best tool for a specific job.If you're using raw for optimal data, Active D-Lighting should always be set to Off. Yes, the embedded JPEG preview image will look better, but you're capturing sub-optimal data.
Hi Thom - Hope you don't mind my added clarification.For raw files the only thing Active D-Lighting does is underexpose them (minimum 1/3 stop at lowest level, as high as two stops at the highest level). This means you'll be bringing shadow detail up and promote noise in raw processing.I often have ADL set to "normal" and shoot RAW only.
If these are consistent you could just take them into account when setting exposure compensation. For example, if you want to raise the shadows but don't care about the highlights, you could set ADL to Medium and exposure compensation to +1/3 stop to have shadows raised without changing the exposure.ADL low = no exposure adjustment but the other settings - Medium, High and Very High - have adjustments to reduce exposure by -0.3, -0.7, and -1.0 respectively. The exposure adjustment is baked into the file - you can actually see exposure settings change.
Nikon Z7 is my camera. I have always kept ADL off in every camera I had but turned on in NX during raw image processing. Not for all images, but for the images I feel ADL improves. I go for the "looks" of an image, not the measured curves or other engineering stuff.Do you turn on Active D lighting, or just correct on post processing?
Nikon used to say in the primarily DSLR era that ADL used in cameras could help protect highlights from being blown out.In addition, ADL applies a curve to protect highlights and brighten shadows. Adobe LR reads the embedded XMP in the NEF file and translates this into an adjustment to Highlights and Shadows.
I have to confess, I don't actually know what 'Active D Lighting' is. Having owned Nikons with that feature for over 12 years now. I'm pretty 'old school', so I just don't pay much attention to such things, and I shoot RAW (+JPEG for archival purposes) anyway, so in-camera processing isn't something I'm bothered about. Coming from a film background, I was used to the distinct lack of DR especially with slide film, so such modern features are a bit 'gimmicky to me. I suppose my own sense of aesthetics means I'm happy with things as shot, mainly. I'm definitely not a fan of the ultra high dynamic range 'HDR' type look that has become popular. Sometimes I will boost shadows a bit in post, but generally only with stuff shot in very poor lighting conditions. I'm more inclined to boost contrast and actually darken shadows for effect. The only time I might fiddle with lifting some darker areas is say for portraits where lifting the eyes a little can help give a bit more pop to an image. But less is always more.Do you turn on Active D lighting, or just correct on post processing?
I love it - especially for video but also for stills. I've used it on two Nikon DSLR and five Nikon Z bodies. At lower ISO the noise impact is minimal and for me it provides a much more natural looking file.Do you turn on Active D lighting, or just correct on post processing?
I'm configuring it to Auto. This releases me from intentionally underexposing high contrast scenes and boost shadows during post processing. Typically Auto means conservative, i.e. helps without causing harm to the picture.Do you turn on Active D lighting, or just correct on post processing?
What about Active D-Lighting set to Auto? Isn't it easy for the camera to decide whether to use it or not based on the contrast in the image -- and isn't it better to underexpose in high contrast cases?For raw files the only thing Active D-Lighting does is underexpose them (minimum 1/3 stop at lowest level, as high as two stops at the highest level). This means you'll be bringing shadow detail up and promote noise in raw processing.I often have ADL set to "normal" and shoot RAW only.
Nope. Anyone that's read me knows that I have a problem with Auto anything. In essence, you're handing a critical decision to an automated process you have no idea how it decides on what to do. Auto can underexpose your image nearly three stops.What about Active D-Lighting set to Auto?
This gets us into the nitty gritty of why this can be dangerous. Nikon's matrix metering, which I'm pretty sure an Active D-Lighting user would select, attempts to preserve highlights. So it's pushing down the overall exposure to start with. There are cases where it won't do that, sure, but you're starting to get into the "in order to use the automation you need to know what the automation is doing" problem.Isn't it easy for the camera to decide whether to use it or not based on the contrast in the image -- and isn't it better to underexpose in high contrast cases?
I find it works with RAW well IF you're are using a Nikon-centric workflow. Start with Nikon software for macro edit and conversion and do the final tweaks with Adobe and such. (if you like the results). Because the ADL rendering affects different areas of the image uniquely...it's not easy to do the same thing in PP...can be done but not quite the same and more involved. I generally work with normal or low near base ISO so any potential loss in DR is minimal and zero with ADL on LowActive D-Lighting was specifically designed for JPEG use. That it works with raw is partly due to the fact that there's an embedded JPEG file in the raw file and that's used for camera review/preview, which you'd probably want to get an idea from how the image could be processed.
I do that with ADL as well and adjust EC as required. Trick is simply knowing what ADL will do with the exposure and it's actually pretty consistent. In most cases, I get a better "look" final image and save time with ADL and RAW...but it only works if you like how it handles the rendering in different areas and use Nikon software. (A similar look to D-Lighting HS but not quite the same).I'm not a fan. My experience is that I get better results simply by paying attention to highlights myself.
