Albert Voss
Forum Enthusiast
http://fotos-dx.de/album03/Vergleich_1 has an interesting comparison between images of an Minolta A1 and a Canon 10D.
Albert
Albert
Albert
one looks good the other like. bad..http://fotos-dx.de/album03/Vergleich_1 has an interesting
Albert
Yikes! that sounds like the worst comparison I've ever heard. Discount it.The pics taken with the A1 were saved as TIFFs with AWB, therefore
the yellow taint (the photographer had the A1 only for a few days).
The 10D pics were taken with the Canon EF 16-35mm/2,8 L USM in
RAW-Format and then changed to TIFF with Capture One, where the WB
was made.
Albert
Albert
A1 that bad?
This comparison is worthless. The one who made those photographs don't know what is color temperapure and was clearly not able to manipulate the A1. Miserable test! Please friends, forget this!http://fotos-dx.de/album03/Vergleich_1 has an interesting
Albert
Probably and hopefully not. "Fritzchen" the photographer of the A1 pics was quite new to his beast, whereas "Wallo" could outgun the A1 with the quite decent EF-lens (See http://www.d7-forum.de.vu/ and there "Über den Tellerrand geschaut" thread "Vergleich der A1 mit der 10D: Teil 1-Abbildungseigenschaften") . And anyway, did anybody expect ernestly that the comparably tiny A1 sensor can stand up to the 6 times biger CMOS thing from Canon?A1 that bad?
was made.
Albert
Probably and hopefully not. "Fritzchen" the photographer of the A1A1 that bad?
I still prefer the A1 "despite" its obvious shortcomings regarding
image quality compared to bigger sensors.
Albert
It were two different persons, both with considerable expirience, as I read from the forum.As I said the person had something to prove, or didn't have aclue.
Or even JPEG to JPEG.Otherwise, they would have compared RAW to RAW.
Contemplating on a 300D, which regarding image wise is more or less the same as the 10D, I of cause thought of getting the C1 Rebel version. But I dont expect that a mere RAW converter can bring about miracles in improving an otherwise inferior out of camera pic. I think this is too much honour to C1. And dont forget "Fritzchen" has bought his A1 already and will probably not turn it in for a 300D or a 10D.This comparison was so BIASED that the person went as far as to
even by-pass using the standard Canon RAW conveter that comes with
the camera and instead used the third party Capture One program
that does a better job at conversion than the Canon converter - it
cost $499 for the pro version alone!!!!
Well not all A1 pictures are taken worse than their 10D counterparts. In the night shots I think they are even. And some of the comparisons are known anyway: the 10D can easily take pics with 800 ISO and even 1600 if you really need, the A1 is limited with 400 (but of course can bring in the AS, which should balance the advantage of the 10d to quite some degree)The guy actually succeded in making the A1 picture look like it was
taken from one of those cheap cameras found in mobile phones...
I agree!!The guy actually succeded in making the A1 picture look like it was
I would feel ashame to publish anything like that when not knowing
how to handle a camera...
Really silly !
Cheers
Jens
Albert
10D: 1472 €The pics taken with the A1 were saved as TIFFs with AWB, therefore
was made.
Albert
It were two different persons, both with considerable expirience,As I said the person had something to prove, or didn't have aclue.
Unfortunately there are practically no one on one comparisons
outside of Phil's site. Therefore I think this is interesting
despite its obvious faults and shortcomings.
Albert
--http://fotos-dx.de/album03/Vergleich_1 has an interesting
Albert
