Excellent!finally got around to doing a pixel shift astro shot, i wish that ricoh would update firmware to allow longer than 30 seconds
so this shot is 30sec pixel shift @1200mm f6.5 800iso Guided on an ioptron ieq45
Have you actually tried doing what you describe with pixel shift? On the K-1 pixel shift does not work in Bulb mode (manual, p 70).Nice photo! Have you tried setting your camera in Bulb mode, then using a wired trigger and timer to achieve 30 sec. + exposures?
Brad,
The Orion nebulosa.Marvelous.
What are we looking at?
cool
I mean that the site only allows a fairly small file to be uploaded the original is rather large , it is shot through a vixen vc200l 1800mm with a telecompressor bringing it back to 1200mmBrad,
I'm interested in your "low resolution" comment, because the resolution at 100% looks better than almost anything else we'd look at -- at 100%. You must mean compared to a Questar which most of us probably don't have.
The color is especially interesting. I didn't know you could get something like that with 1200 mm -- but of course you can't without something like your ioptron I suppose.
Out of curiosity, what level Questar would you need to buy to get better resolution?
Lawrence
Yes, that would be nice to see.Great picture for sure, but did you compare with and without pixel shift to see if there's a real improvement ?
Dan
