80D: ext. flash fires but pictures are dark + built-in flash doesn't fire
gico62
Well-known member
IT
Hi,
big drama last night at my daughter's 18th birthday: both flash stopped working.
In the beginning everything was fine with my Canon 80D but then something happened. I gave the camera to another person for a while (but I suppose she did not change any setting). After that I could not use flash anymore: ext. flash started firing too much and pictures were almost white, built-in flash did not fire anymore.
Now, this is the situation:
Built-in flash doesn't fire anymore.
Extrnal flash (Yongnuo EX500 mounted on hot-shoe, E-TTL) fires but pictures are dark (like flash fires before or after the shot).
I'm testin using P program, checking again and again flash settings in camera and on ext. flash, resetting flash settings from menu, resetting camera settings... nothing to do.
Any idea?
Thank you in advance
GC
Model Canon EOS 80D
Shutter Speed 1/60 s
F-Number f/4
ISO ISO 400
Exposure Bias Value 0.00 eV
Metering Mode Pattern
Flash On, Fired (and it really did!!!)
Focal Length 32 mm
Lens Model 17-50mm
White Balance Details Auto
Date/Time Original 07/09/2025 08:37:18
I have one but hardly do flash. However, I have a Manual flash and set cameral shutter at 1/250. Don't know if this helps..
I am wondering if somehow some setting was changed. You might try a camera reset.
