Reccommed Adapter For Nikon 6T
Daniel Ruth
Well-known member
Bristol, RI, US
I am going to purchase a Nikon 6T, but what I don't understand is what adapter I need. I know that the end that meets the 6T needs to be 62mm but what about the end that attaches to the camera?
At Shenes web site click on the FZ10 link and you will understand better
http://www.cs.mtu.edu/~shene/DigiCam/
Kodak DC-4800
Panasonic FZ-10 and FZ 20
T Con 17 -- Raynox 2020 pro -- Tcon 14 --DCR 720
Just trying to learn and it's slow going!
Gene
Panasonic FZ15
I am also confused now (again!). I just read a few posts on the Nikon 6T and the users say that it works best if you use it between 1x-3x, I thought that the 6T would work all the way through the focal range (12x+). If it only works us to 3X what is the sense in not just using macro mode?
You will need to purchase an adapter (62mm) from either of the following (in the case of the Pemaraal, once they have restocked):-
Pemaraal:- http://www.b-300.com/
Yoshida:- http://butabara-tec.com/
Mr Chen's adapter:- http://vipweb.url.com.tw/mschen3/
Phayee (China) (via eBay) :-
Pro-Technica Co. Inc (Hong Kong) (via eBay) :-
The Mr Chen adapter is the hardest one to purchase but to my mind is the best adapter of all those listed above.
Photosolve and Raynox also do adapters but I do not have their website URL's to hand.
Visit Shene's website for further details on adapters and most things relating to the FZ10:-
Harryo
In my FZ10 and now FZ20, just using the in-camera lens and in macro mode, it is correct that the effective zooming range is only up to 3X. Adding a macro lens like the 6T will increase this zooming range beyond 3X and increases distance to the subject (you could use modes other than macro as well). If your hands are steady or you coulds use a tripod, I have tried going into the digital zoom range. Though I don't have the FZ3 nor tested it, I could only speculate on a similar limitation. Here's the link to my old 6T shots with FZ10.
cheers,
gil
Yoshida has told me that his adapters do not work with the Nikon 6T. He says there is something wrong with the thread spacing.
Later,
Steven
Just having fun with my cams:
http://www.pbase.com/swhatleys/
Later,
Steven
That is very interesting what you say about the Yoshida adapter and the Nikon 6T Steven, I was not aware that there was a problem.
Although I must admit that I only use my Yoshida 58mm adapter with Sony lenses and fitting is easy.
Out of interest I have just tried fitting the Nikon 6T to the following 62mm adapters:-
Pemaraal PD62:- the Nikon 6T is hard to screw on but it will eventually go on. I also found that some of my 62mm filters were hard to screw onto this adapter initially but after a bit of use fitting became easier.
Pemaraal PA62H:- The Nikon 6T will screw on without too much effort.
Phayee:- The Nikon 6T screws on easily.
Mr Chen:- The Nikon 6T screws on very smoothly.
Harryo
How does one actually buy Mr. Chen's product?
Harryo
Walter Mitty
(Everyone has a secret life.)
This is Yoshida's words (translated to English by him):
2) It seems not to be able to install Nikon 6T in my adaptor.
The report was received in the past.
The interval of the thread of Nikon seems to be different from
other one.
Later,
Steven
72mm-62mm step down ring will work. See http://forums.dpreview.com/forums/read.asp?forum=1033&message=10385742
To clarify: The fz series macro capabilty is limited to 1x - 3x zoom. The use of a close-up lens such as the 6t will allow macro capability through the entire 1x - 12x zoom. See http://www.ishots.net/fz1-2faq/fz1macros.htm Applies to fz1/2/3/10/15/20
Fred
FZ1v2
Not sure if anyone has answered this but the 6T is essentailly a magnifying glass on the front of your lense. It reduces the focal length and depth of field. Essentially restricting how far away from the subject you need to be and how much you can zoom Afterall it is a close-up lens for macro work. You wouldn't normally be taking a macro shot of something 50 feet away would you?
Lewis
http://chilipalmer.deviantart.com/gallery/
Okay, so now I get everything, thank you so much for your help! One other thing, I read on some site that someone linked to me that the smaller the step-down ring (the closer to the lens) the better? Is this true, because someone highly reccommends the PD62 and it's huge (and more expensive) then another stepdown ring I found that was only a couple of mm wide and $15. Can someone give thoughts on this?
this?
A step-down ring is not the same as an adapter.
An adapter with a 62mm thread will allow you to use for example the Nikon 6T lens without adding any further accessory.
A step-down ring 62-55mm would allow you to use for example a teleconverter such as the Olympus TCON-17 which has a 55mm rear thread with an adapter which utilises a 62mm thread.
The adapter is a much more substantial item compared to the step-down ring hence the difference in price.
Harryo
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=43441&item=3843716543
It's a Phayee adapter. I was a little nervous about bidding on an item from China but it arrived VERY quickly, although with Chinese directions! LOL! Fortunately it is easy to figure out how to use it.
I have the b-macro and the mcon-35, which I understand are very similar to the Nikon lens, and I can use them all the way through the zoom range. I haven't had a lot of time to play with them, maybe the best quality shots are at the lower end of the zoom, but that is also where you get vignetting if you use the wrong adapter.
Theresa
Constructive criticism always welcome! :)
http://www.pbase.com/theresa_k
Panasonic FZ-20, Oly C-5O6O & FL-4O
I have one of those on the way ( like I need another adapter). Do you like yours and did you get a additional hood for yours? I am not sure which hood to order.
Some have said that the PHayee is a knockoff of the chen adapter and does not fit correctly, any comment?
Kodak DC-4800
Gene
No, I have my panasonic hood I can always go back to. The adapter is in two pieces, the outer one kind of acts like a hood anyway but so far I have only used the inner one to fit my mcon-35 and wide angle lenses.
It's working for me! I bought it because of availability. I emailed the permael (sp?) people, they said they wouldn't have any until the end of September, it is now October and they still don't have them. I had lenses collecting dust, figured for $20, what did I have to lose?
Theresa
