Yes I tried the paper diffuser trying to get to f22 but couldn't
with that working distance.
Paper diffuser? What's that? Did you use the SB-800 plastic
diffuser? That easily gets to f/22, is slightly underexposed at
f/32, and that's with the head pointing directly at the subject (7
1/2 degrees below the horizontal), although with the diffuser I'm
not sure what difference it makes the angle you set the flash.
Note my shutter speed setting: 1/500 of a second. I wanted to make
sure that it was only the flash that participated in the exposure.
I deliberately did not want balance-fill, and shot in manual mode
(let the flash supply (virtually) all the light). This is what it
would have to do anyhow deep in the forest.
No, I did not. If I understand this correctly (please correct me if
I'm wrong), you set the camera up as described, press the trigger,
then move back and forth until you hit the focus and the shutter
automatically goes off. That would be fantastic (and exactly what
hand-held macro photography would need) if this is true. Can't wait
to try it out.
Thank you for giving me that reference on macro focusing.
FJP
