Hi
I'am a beginner with my new D70. I will be leaving soon for the
mountians on vacation for a week and would appreciate any
suggestions for bright sun general nature shots.
Paul
--I keep an UV or skylight filter always on my lens for protection.
The only additional filter I use is a polarizer to get deep blue
skys or avoid reflections in water. Most other creative effects can
be achieved later using Photoshop, if you like.
Make sure you have a good filters. In my view the multi-coated B+W
and Nikon filters are the best, Hoya are also OK, but difficult to
clean.
I wish you a pleasant vacation with a lot of excellent pics.
- Olaf
Hi
Paul
clean.
- Olaf
Hi
Paul
--I am also looking for filter as protection. Why Nikon filter is
best ? Is it super multi-coated ? How much does it cost ? Why Hoya
is just OK and difficuilt to clean ?
Thanks.
clean.
- Olaf
Hi
Paul
If you are not in the lens protection school, you only need the following: polarizer, various grade neutral density (ND) filters and gradual ND filters. The effects brought to you by these three filters cannot be (or at least very difficult) to replicate by image editing system. If you buy the lens protection idea, you'd better also buy a collapsible rubber lens hood because rubber can absorb more impact force than a filter can.I'am a beginner with my new D70. I will be leaving soon for the
As already mentioned, a polarizer is a must, a grey graduated cokin filter for too bright sky and a protector filter as UV or skylight. I know some will disagree with the protector filter, but I do not want to take any risk with expensive lenses.Hi
Paul
[/B]I am also looking for filter as protection. Why Nikon filter is
Thanks.
clean.
- Olaf
Hi
Paul
The polarizer effect can be easily and satisfactorily reproduced in Photoshop while the ND filter can not - at least not very easily. If you shoot your pics without the polarizer filter, you can decide in front of your computer which of them looks better under this effect. BTW, playing with the curve effect on PS also gives very similar effect to the polarizer.As already mentioned, a polarizer is a must, a grey graduated cokinHi
Paul
The polarizer cuts light already by 2 stops, so I am still
resisting buying a ND filter.
Cheers
Jacques
I've found the lens pen cleans Hoya filters very well.Has anybody found a good solution for cleaning Hoyas?
The polarizer effect can be easily and satisfactorily reproduced inAs already mentioned, a polarizer is a must, a grey graduated cokinHi
Paul
Cheers
Jacques
Shmuel
Paul
Cheers
Jacques
Shmuel
As previously mentioned, get a circular polarizer. It will make a
stunning difference in your images.
A graduated ND filter will help long landscape shots, particularly
in the mountains. When you are shooting mountains in the distance,
they tend to be underexposed, while your foreground is properly
exposed. See http://www.tiffen.com/color_grad_filters_pics.htm
near the bottom of the page at the Color-Grad ND filter example
pics to see what I mean.
I took a mountain trip last fall, and wish I'd gotten a ND filter
before I went. I'm leaving next week to go back, and I need to
order one before I go.
On my last trip, I also took the Tiffen Enhancing filter to boost
the reds in the fall folliage. It worked really well. For samples
of this filter, see http://www.tiffen.com/enhancing_filter_pics.htm
. This might come in handy if you are going to a part of the
mountains where there's a fair amount of red in the rocks. It
worked really well on the red aspens.
Good luck.
pjordan
PS: I've had good luck with tiffen filters. I know a lot of folks
on this forum prefer other brands. I'm pointing out the links
above b/c they are pretty good illustrations of what the filters
do. I don't work or sell for Tiffen, so please don't consider this
spam.
