Jared Hunter
I picked up a cheap (approx $20 US) linear 58mm Hoya polarizer for my 8080 today. Don't bother with the more expensive circular polarizers unless you intend to use them on SLRs. The outer ring that you turn is nice and loose (but not too loose) unlike my other polarizers which feel a little gummed up. Here are some comparisons showing the polarizer set to minimum vs maximum effect.
I usually shoot in aperture priority mode. To adjust for maximum effect, I rotate until I see the shutter speed drop to it's slowest meaning that the effect is most intense resulting in a darkening of the image which the camera must compensate by slowing the shutter speed.
http://www.pbase.com/image/29487357/original
http://www.pbase.com/image/29487358/original
(any blotchiness you see in the sky is cause by jpg compression, not the filter)
