We've been trying to figure out how to make 2 different 5 X 7
prints on a page. So far, no lluck.
In case you are interested, this is the method I use with Photoshop
to quickly print different images on the same page.
I sat down one day and made up a bunch of templates, for example,
to print two 5x7s, four 4x5s, etc.
Each template has two layers - an empty background (slight grey,
just to make it easy to see), and an overlay of pure white with
transprent holes cut into it of the exact size desired. The
template file is sized to fit the desired paper and set to the
desired printing resolution.
I open each picture to print, flatten if necessary, then drag from
the layer palette and drop directly on the template window.
Reposition the layer in the palette (if necessary) so it is beneath
the window in the white "frame", and use the Edit/Transform/Scale
command to resize to fit the hole and position the image in the
frame. (Hold down the shift key while dragging a corner to keep
the proportions of the image correct). BTW, the scale
transformation uses Bicubic interpolation by default.
The nice thing about this method is you can resize the image to fit
and "crop" and position all in one step. Hit enter to finish the
resize and repeat with the next image. If fitting the image in the
window causes an overlap of the image below it in the layer stack,
I select the excess with a quick rectangular selection and press
Backspace to trim. It's also real quick to slap a Levels
adjustment layer on just one image if I see it needs it when
adjacent to the others on the page. I usuallly flatten and save
the composite page so I can quickly reprint later if needed.
If this sounds like a lot of trouble, it's not. The whole process
is far quicker to do than to read about. I use a few actions to
make it even quicker.
BTW, when making a new template, I use the "Fixed size" option in
the rectangular selection parameters to set the exact size of the
hole to cut into the frame, drag the rectangle to snap to some
guides, then press Backspace to erase the hole.
I have templates for 2, 3, and four images of various sizes,
including some at 4.5x6 which is the exact aspect ratio of my
digital camera (Olympus E-10) to print without cropping. With
carefully positioned borders, this is also a nice way to compose
two complimentary pictures into a single 8x10, ready for framing.
Sorry if this is not what you had in mind or if you already know
all of this, but someone else may be interested. This is by no
means an automatic process, but it's very quick, ultimately
flexible, and free.
JKJ
