isacsop
Well-known member
Hi!
Where can I find the newest USB-driver for 300D?
Thanks in advance
Per
Canon 300D/CP5700/CP4300
Thanks in advance
Per
--Hi!
Thanks in advance
Per
You shouldn't need a USB driver for either 2000 or XP, USB support is built in. For Win98 you would need a driver. Any USB device plugged into a 2000 or XP machine should show up as a drive in Windows Explorer. (Although, if you install the Canon software, the 300D won't show up any more, and you will have to use ZoomBrowser or the Canon FileViewer utility to access your images.)Per
--Hi!
Thanks in advance
Per
Important note: switch your camera to Communication: 'PTP' mode,You shouldn't need a USB driver for either 2000 or XP, USB support
Windows Explorer.
