Another consideration. Your 5000 prints dry micro prints at about 190
lines per inch which will provide a very nice print. This print will be
very color fast, far more than any other consumer printer that I know of.
I've been testing a variety of media for color permanence and the Alps MD
5000 dry micro prints are by far the best. They are comparable to "lab"
prints on good Kodak paper. The bad news: the dye sub is less color
fast than most ink jet printers. I performed very poorly in my tests.
While the dye sub prints are a tiny bit better than the dry micro prints,
in my oppinion, the nod goes to the dry micro prints for overall use.
This also saves you $100 or so.
No offense Leon, but you have been persistantly posting that the Alps dye
sub prints fade quickly. My dye sub prints have yet to fade. I've had
the printer for over a year. You have also posted that you don't even
have the 5000p, but the 1300. You have been the only one who claims that
the 5000p isn't color-fast. How can you comment on the color-fastness(is
that a word?) if you don't even have the printer you are commenting on.
Seems that no one in the onelist alps section has posted about similar
results. What gives?
I owned the original photosmart. The alps in dye sub was considerably
better. Really not even close. My sister owns the Epson 750. While it
produces an excellant quality print, in my opinion, it's not as good as
my alps print. Although, it prints faster, obviously so, I have a 1520
that I use for everyday use. The cost per print is maybe 80 cents more
per 8x10 print. But for 80 cents more, I have a print that from the
start is better, water proof, and in my experience lasts longer. I have
yet to have to reprint any pic.
So I guess I just don't have the same results that you do with my 5000p
as you do with your 1300.
Eric Miller
Eric, As near as I could tell, the dye sub print process is identical in
the MD 1300 and the MD 5000. Both printers use the same ribbon set and
the same paper and have the same resolution of 600 dpi. I did two
testing runs comparing Epson, HP,and Alps prints in a daylight window
that was bright but with little sun. I printed two of everything. The
first copy was the reference and the second was the test copy.
Comparisions were done with my scanner and photoshop which allowed me to
quantitatively measure the fading of the test
images. The images were a collection of thirty color swatches along with
some portions of images for the subjective part of the test. I did two
separate tests of the Alps print processes and the results were the same.
The dye sub faded significantly quicker than the Epson OEM inks in an
Epson 700. Since I can only approximately quantify the lux exposure in
my tests, I use Epson 700 prints for a standard. I generally state
results as better or poorer than the 700 prints. I'm not surprised that
your prints have lasted a year. Under normal indoor conditions, a year
is not unreasonable. If prints are kept in an album, the life can get
much larger. As far as why I am the only one stating results on color
fading, so far, I'm the only one that has gone to the trouble to do
actual tests on some of the mainstream printers and reported them. I
bought the MD 1300 because of the things that I read on the net that dye
sub printing was very color fast and by implication the Alps process
would be too. Unfortunately for my pocketbook, that turned out not to be
true. I have an Alps MD 1300 for sale real cheap. Interested? If you
are interested in doing your own prints, I will be willing to send you my
test image and some Epson OEM prints so you can see for yourself.
