M
matt chase
Guest
I have actually had this problem a few times in the past few months, but hoped that it was just the situation (ie bad lighting, subject, etc). However, in daylight (albiet dusk), once again my camera would not focus when held in a vertical composition. It did this once before in bright sunny light as well. In both instances, I was photographing a headshot of a person, and had the focus circle on their face (bad focus), chest (bad focus), collar (bad focus), hair (bad focus), etc. In both cases, I also shot many horizontal shots, from the same approx. distance and same approx. focal length, with absolutely no focus problems. The fact that both times I was in daylight, and both times I had no problems with horizontal compositions, I wonder if my camera has a bad or malfunctioning sensor in it. The odd thing is / and the reason I haven't said anything before is that in other times I have done verticals with no problems at all.
As a technical note, I don't think I turned off IR focusing either time. I know I didn't on the last occurance, as I was limited on time and was just trying to get the shot over and done with. But the other times I don't remember, they were too long ago. Either way, shouldn't the focus be working a little better than this in a vertical composition?
The camera is otherwise perfect. No stuck pixels. Only 1 light gray hot pixel at 8 seconds exposure time. Colors are good. Exposures are good. I really don't want to send it in and risk these other problems unless I really have to.
Just fishing for opinions...Thanks.
