Ummm, isn't it 4:5?what is the ratio that i can type in for a crop using the crop tool
in photoshop for an 8 inch by 10 inch crop.
i can type in 8 x 10 inches but i want to crop to a raio (for 8x10)
not the actual measurement.
--what is the ratio that i can type in for a crop using the crop tool
thanks,
joe
thanks,
joe
Barry in Frederick, Md.
thanks,
joe
This probably seems like a bit of a silly question when it is first read, but if you leave the crop tool's resolution setting blank in PS, it will simply crop the image w/o physically resizing it. It will set the image's dpi (resolution) to whatever is needed to mathematically say it is the chosen 8x10 inches at the cropped number of pixels.what is the ratio that i can type in for a crop using the crop tool
thanks,
joe
Joe - I use the "calculator" thats on my computer as part of the programs. Set it on your task bar ready to use.what is the ratio that i can type in for a crop using the crop tool
thanks,
joe
thanks,
joe
See my other post on this topic -- put in your crop size in inches, not pixels, and leave the resolution setting blank. In most cases, ther will be no resampling -- the dpi setting of the resultant image will be recalculated, though. I believe thre might be situation where resampling occurs anyway, but don't remember the details of that.Joe, I understand what you are asking, as it is a question I have
asked without getting a satisfactory answer. In both PS and PSE, I
find no way to set a ratio. If you put 4:5 with no DPI, you get
4x5 pixels, and so on. If you put a print size, like 8x10 or
11X14, the crop tool gives you a resampled result.
Not true. In Elements, just as in Photoshop, if you put in 4 in one box and 5 in the other with nothing in the Resolution box, the program automatically adds inches to your numbers - you end up with 4" x 5" with no interpolation. The only way Elements will go to 4x5 pixels is if you put 4 px and 5 px in the boxes.Joe, I understand what you are asking, as it is a question I have
Not true. It does that for you, because you have your units set to use inches. If you enter no units, those crop width/height settings use what your PS sytem is set to use as default units. Try turning on the rulers for an image, change the display to pixels & try entering 4 and 5... you will get pixels.Not true. In Elements, just as in Photoshop, if you put in 4 in one
Okay, I'll go along with that. I should have said at default settings .Not true. It does that for you, because you have your units set toNot true. In Elements, just as in Photoshop, if you put in 4 in one
- Andy
thanks,
joe
