I've been reading this and the 300D forum for quite a while now.
I've seen just about every type of question answered and answered
well. I just bought a DRebel and am researching lens.
My question is how does one go about converting MM to feet. In
other words what is the equivilant of a 50MM lens in feet? I know
a 300MM lens will reach farther than a 100MM lens but I can't get a
gauge on how to calculate the distance.
Thanks,
Lenses don't have "reach" in that they don't capture only up to a
specific distance. Rather, the focal length determines the
magnification of a given object on the image plane. Combined with
the size of the sensor, which determines what size area of the
image plane is captured, and you end up with a certain field of
view. Objects will look larger when captured with a lens of long
focal length. However, the size of the object itself is important.
A small object that is far away will require a longer focal length
to fill up your frame compared with a large object. Perhaps you are
asking the following question: to fill my viewfinder with a
specific object at a certain distance, what focal length do I need?
If so, we can answer that as follows:
On the focal plane, for a "distant" object (distance > > lens focal
length):
Size of projected subject = (Actual subject size) * (focal length)
/ (subject distance)
You want this size to be equal to that of the sensor size, to fill
up your field of view. Thus:
(sensor size) = (Actual subject size) * (focal length) / (subject
distance)
which can be rearranged to yield:
(focal length) = (sensor size) * (subject distance) / (actual
subject size)
If we focus on the vertical dimension, the sensor size is 15.1mm, so:
(focal length) = (15.1 mm) * (subject distance) / (actual subject
size),
with the distance and sizes in any units you want as long as they
are the same (both in feet, for example). The focal length result
will be in millimeters (mm).
Thus, to capture the complete body (top of head touching top of
frame, bottom of feet touching bottom of frame) of a 6ft. person
standing 6ft. away, you'd need about a 15mm lens on a 300D camera.
David
