This is a long and boring topic, unless you've had the problem.
I have discovered one reason for the intermittent no-flash or low-flash problems I have had. In my case, the problem is fairly simple. I'm using a Sto-Fen diffuser and a Metz flash.
The reason the Metz is a problem is that both the Auto and TTL flash programs use information from the flash sensor as well as the camera sensor to determine when to squelch. This would be O.K., but...I'm using a Sto-Fen flash diffuser. I was certain the problem wasn't random, although it seemed to be. What is happening is that the Sto-Fen, when the flash is in direct flash mode (facing forward), spreads the light in such a broad pattern that it reaches the sensor on the flash before it reaches the subject. This causes the flash to either squelch early or lessen the flash power, I'm not sure which. My best guess is that it squelches early.
If the flash is in bounce position or rotated horizontally, flash is normal and exposures are as expected. If the flash is in manual mode, naturally it flashes regardless of position, because the sensor is taken out of play.
I am of the opinion that Metz is aware of the problem because they recessed the sensor, but apparently not enough. I also noticed that they have stopped selling the Sto-Fen as an accessory.
I was able to verify my suspicions by simply blocking the light coming down from the flash by holding a piece of cardboard under the head or removing the Sto-Fen. With the cardboard in place, and the Sto-Fen attached, the flash fired every time. Remove the cardboard and the problem returned. Remove the Sto-Fen and the problem disappeared, replace it and it returned.
Block the sensor with my finger, the problem disappeared, remove my finger and it returned.
I suspect that this is the reason some of us get intermittent flash on occasion, usually in less than optimum light conditions. If the ambient light is bright enough, the extra light from the flash doesn't have as much of an effect. In lower light conditions, usually normal room light, the flash sensor sometimes reads the light from the flash before it reads the light returning from the subject and shuts down too soon. This can happen even without a diffuser in place, on occasion, and depends on the flash design. I don't think the problem is unique to the Metz 40MZ 3i, but since those of us who have complained about it haven't said what flash we're using, I don't know what other flashes may have the problem.
I don't know how to tell you to test your flash. I just had an "ah ha" experience when my flash didn't fire properly. It was flashing, but just a "small" flash, and something "clicked" for me.
If you're having an intermittent flash problem, drop a line to say what flash you're using. There may be a commonality that we've missed.
Pat Glenn
Pat Glenn
