there is a magic wand and a magnetic lassocan anyone please explain how i adjust the area selected by the
lasso in ps7.
Http: imageevent.com/sc00by/
lasso in ps7.
the magnetic lasso has it's limitations
also another very common thing you need to do when using the lassothe magnetic lasso has it's limitations
there is 0 contrast between the tire and the shadow so the lasso
sees no edge
you can try playing with the settings of the lasso on top like
decreasing the distance or increasing the sensitivity, but try this
first:
when you first get to the area where the contrast decreases at the
tire, click every few millimeters as you go around the tire, the
lasso will follow your clicks instead of the edge
feivel
to add to the selection hold the shift key while using any tool to select what you wish to addFunny you should mention this Chuck - I had a similar situation
just last night and after the entire object was selected, I wanted
to move/adjust my selection. I couldn't figure it out and so I
went to the ps7 help file. No luck. Can this be done or do I have
to make it perfect the first go around?
--posted by scOOby
http://www.dpreview.com/forums/postersprofile.asp?poster=hjilifilheid
i bet he has no idea how he did that.
the server probably hiccuped.
feivel
--correct, and i've no idea why my name didn't show, perhaps it's my
alter ego!!!
--posted by scOOby
feivel
--Well, maybe your name had some special character which cannot be
rendered properly, or may be a 'soft-space' - Alt+255. IF I am
correct, my name wont come on this message - if Im wrong, you would
know, ofcourse.
regds
arjun
alter ego!!!
--posted by scOOby
feivel
http://www.pbase.com/arjunrc
know, ofcourse.
regds
arjun
alter ego!!!
--posted by scOOby
feivel
Thomas Niemann
http://epaperpress.com
