Our S2s (and most DSLRs and 35mm SLRs I can think of) use "focal
plane" shutters.
This is the limiting factor on our sync speed. Above 1/180 second
the entire sensor is not illuminated all at once. At 1/1000 the
shutter actually "wipes" a sliver of the image accross the sensor.
At any point on the sensor the light hits it for 1/1000, but not at
the same exact time! There are high speed flash systems that
attempt to "strobe" (repeat flash really really fast) long enough
to get all of the sensor covered. But, they are low powered
compared to a standard strobe :-(
I'm not sure if any of these high speed/low powered systems will
work with the S2.
Most of the pro wedding/portrait photogs who want/need high speed
sync for outdoor flash fill work with a "leaf shutter" camera
system. Most of these systems are medium format cameras. They will
sync at any available shutter speed. They do have other limitation.
They are not typically real fast. The Mamiya RZ I use at a studio
job maxes out at 1/400, I think the classic Hassy's max out at
1/500. Each lens has its own shutter, so they are expensive.
I had a student with a Nikon D1x that claimed it used an electronic
shutter above it's sync speed and could thus be synced at any
speed. Check and see if she is correct (I didn't test).
Oddly your (reasonably priced) answer may be in getting a cheaper
digital "all in one" camera. Many P&S digitals use an electronic or
leaf shutter and will sync at all speeds. My Sony F707 will sync at
all speeds. It seems to under expose slightly with flash at 1/1000
it is fine at 1/500.
Hope that helps.
Hi
I have bought my S2 pro
is there anyway I can get the 1/125sec high speed sync to be
ncreased, im hoping near 1/1000sec
also wht would be a good flash for the camera. I need one that has
wideangle coverage of 17mm, multi flash, quite powerful
thanks
Tom Ferguson
http://www.ferguson-photo-design.com
