Sepia Effect
Paul Dhadialla
Well-known member
CA
Hi guys ! What do you recommend as the best way to achieve a SEPIA effect in PS7.
Thanks kindly
Paul
effect in PS7.
Thanks kindly
Paul
Hi Paul,
There are lots of ways to get a Sepia tone in PS7. I personally use a plug-in filter by Flaming Pear called Melancholytron. It gives you lots of wonderful options, like vignettes and bluring of edges and it's a quick and easy tool. I use it on most of my Black and Whites. I do, however, advise you to use it judiciously. A little bit of Sepia goes a long way.
For more info on Flaming Pear: http://www.flamingpear.com/
Here is one of mine that I toned with "Sepia".
Fred Miranda's set of B&W actions contains some duotones and tritones that are varying gradations of sepia. Check them out.
effect in PS7.
Thanks kindly
Paul
It has to be about the Art, but it is also about Science
Hi, I use PSP7 (It came with my Dell and, based on my experience with the program, I've had no reason to spend any extra money on PS7). I use two methods:
1: "Colorize," setting hue and saturation both to zero for B/W or else hue at 10 and satruation at 40 for a sepia look. Usually I leave the untouched image at the bottom and create a layer for the sepia. That way I can "erase" the sepia layer for a handcolored look or else I can go into "layer properties" and make the sepia layer 75 to 80% visible so that you can see some of the underlying color. This gives a great antique/handcolored look.
The only problem with greyscale is that if I choose grayscale, all layers are grayscale. This can be overcome, but only with many many steps/cutting and pasting. With the volume that I do, I can't afford to go through so many steps.
2: "Colorize" zero/zero for black and white; and then "effects; enhance photo; automatic color balance" then select a color temperature of about 4500. This gives a great sepia color. It also doesn't affect my underlying layers.
Hope this helps,
Michelle
