That is not strictly true as some of the summary comments are
factual
You have to be careful because even apparent "facts" may be incomplete or misleading.
e.g. the V1 has the fastest autofocus
That appears to be true in the tests, although it's hard to say under what conditions this will be noticeable. In low light, with larger objects, and within 10 feet, eys, the V1's AF should be better and faster. But with smaller subjects, farther away, or under normal lighting, we have no data for comparison.
Where subjectivity comes in is in the final rating. The Sony (he
explained) gets the highly recommended tag because it does what it
does for a cheaper price then the other two.
After you consider its limitations, and the required added cost of an extra battery and much more expensive Memory Stick Pros, the price difference disappears.
Even if you overlooked this important point, I still think the G5's (or G3's) faster lens, longer battery life, articulated LCD, better ergonomics, and other features are easily worth an extra $100.
And the V1 is not even remotely what I would consider a compact camera. It only seems that way when viewed from the front. Sony routinely designs many of their cameras in a way to make them appear smaller in photos and displats, while their true size is revealed when you look at the thickness.
The interesting thing, given the increased CA of the G5 over more
of the apature range is can you compare these subjective ratings
from reviews done at different times in isolation? For example the
Oly 5050 has very similar comments about CA and noise as the G5 but
is the cheapest camera to buy of any of them so should it get a
higher rating?
As I said, that rating is meaningless.
By the way, you're overlooking the G3, which has all the same features without the nmosie or CA problem, and a lower price.
I suspect that Phil, like myself and many others, is a little
peeved that Canon would have the audacity of releasing a G3 with a
black paint job and an extra megapixel as if it were a brand new
model, especially with the pretentious G5 moniker.
I don't think he is in that he explained why the G3 was not called
the G4 (4 sounding like "die" in asian markets) and since the G5 is
a progression from the G3, even a small one, spec-wise what would
you have them call it?
Anything but G5. Call it G3 Plus, or G3 SE special edition, G3e, G3i...
The real new model will be out next fall.
The V1 is no competition for the G3 or G5, and I don't think Phil
intended his subjective comments to be used as a basis for
comparing them. The V1 has a slow lens, limited battery life,
non-articulated LCD, and the Memory Stick tax.
Well to quote Phil form another post in another thread when
comparing the G5 and V1:
So to say it does not compete is IMO wrong.
See my responses to that comment.
It may kick the butt of the S50 (with which its pricing should be
compared) but it's not worthy of comparing to a G-series.
Well you are talking nonsense now. If something that is faster,
more responsive with a better lens and lower noise is not worthy of
comparision, what is?
OK,. I guess I AM going to have top repeat myself...
"V1 - faster, more responsive
It's autofocus may be faster, but you can't say the same thing for its prehistoric 3 shot burst mode and lack of a true continuous shooting mode and buffer.
, more compact (you're more likely to
bring it along),
Unfair comparison. As I said before, I don't think the V1 offers anywhere near the versatility of larger cameras like the G-series. As such, size comparisons will be misleading at best.
If you say it's small compared to a G, that's unfair because it doesn't do the same things. And if you say it's large compared to the S50, that is also unfair because it can do a little more.
Overall, though, I'd say its capabilities and limitations are closer to the S50 than the G5.
better value for money (cheaper),
Again, compared to smaller cameras, it's actually overpriced. And even when unfairly compared to a G5, you must consider the additional $60 cost for an extra battery to attain reasonable battery life, and an additional $50-100 or more for the Memory Stick Pro's additional cost over CF cards.
The G5's faster lens, LCD, and battery life alone are easily worth an extra $100. But after considering the hidden costs I just mentioned, the V1 is actually overpriced even compared to the G5.
image quality
almost as good,
Provided the slow lens, poor battery life, poor ergonomics, and limited high speed shooting don't keep you from getting the desired shot.
What? I hardly consider an f2.8 lens better than an f2.0 lens.
A swivelling LCD, a one stop faster lens and longer battery life
may be more important to some but others may well conclude the
areas where the V1 is clearly better than a G5 are the more
important factors to them.
The only cool thing I see in the V1 is the autofocus. It is not even remotely compact, and its slow lens and other limitations make it an unacceptable direct alternative to a camera like the G3.
In otherwords it is now you who are coming out with the subjective
view and presenting it as fact.
I never said Phil was wrong bto be subjective. I just said to take his subjective comments with a grain of salt because they are not based directly on had data.
I reserve the same right to express my own subjective opinions.
