Ole Petter Rønningen
Member
My 70-200 is ok but my 16-35 now ff's. It seems to have fixed blown
highlights though. Can you load 1.00 by renaming it 1.02?
--Make absolutely sure that the file name is correct:Thank you Olga, I checked the file on CF card, it's there (1.27MB),
but not in Canon folder though, it's side by side with Canon
folder. I insert the card, tun on the 10D, still nothing happend.
10DV101.fir
Earlier in one of your messages it was misspelled, or at least the
dot was missing.
Olga
JayCee
http://www.pbase.com/jaycee_photo
Lars just posted the same thing I was getting ready to suggest.that was misspelled. IT IS 10DV101.fir
--The 28-135 IS is my usual short lens too.
Speaking of this lens I discovered that the image drifted
consistently down and right when I turned on the IS with the camera
on my tripod a few days ago. Thought my ball had started slipping
but it was rock solid and on target with the IS off. The IS on the
100-400 has never done this.
Hu
See
and remove the ';' from the link!
--No, not me. For my first 10D reset had no effect at all and I haveI'm sure that Pekka or someone actually proved it with before /I'd sure like to hear Canon's explanation of this phenomenon.
after shots when it was initially mentioned and it seems to have
worked again, if it hadn't my 10D would have been back to Canon as
the first shots were rather soft! . it's just fine again now![]()
not done it on the new one yet because everything works. Now we
have one question left: what does the reset do for GOOD cameras?
Please ignore the Typos, I'm the world's worst Typist
The No1 Dedicated 1D forum in the UK -------->
http://www.1dforum.co.uk/php/phpBB2/
Pekka
http://photography-on-the.net
http://www.pbase.com/kevinv
To add to that the displayed settings might not be accurate either if callbacks or a publish/subscribe design pattern was used and there's a bug in the initialization of those routines. As you pointed out though, we as end users have no way to confirm what's actually going on aside from observing the symptoms.Actually I don't know any way to confirm what I think is going on
except second hand much like a doctor seeing the symptoms and
reaching conclusions. everything that firmware controls on the
camera isn't displayed. We are only shown how it sets a few mostly
hardware settings on the menu.
--I've dl'd the EXE, now what? I assume you'd copy it to a CF card.
Does it then auto-install once in the 10D?
