Andrew Burke
Member
If you look in the center of the bottom left quarter of this image, there's a dark smudge. I only just noticed it, and found that it's on all similar images.
99 percent of the time it's hidden by generally darker parts of images. The lens is clean, like new.
Would you consider this an acceptable glitch, or do you think I should go ahead and have the camera repaired? Otherwise it's perfect.
BTW, this sample is of a seed floating in murky water...
Thanks,
Andrew
Thanks,
Andrew
