http://www.steves-digicams.com/rx2000.html
For information on the various Nikon flashes (text only), see:
http://www.cs.kau.se/~nicke/private/photo/speedlight/menu.html
The SB-24, SB-25, SB-26, and SB-28 all have similar power and
bounce capabilities. As far as the CP950 and CP990 are concerned,
there is not much of a difference between these flashes. The SB-28
is smaller and lighter than the others, but there is no reason to
buy the SB-28 if you already own one of the other speedlights.
I just received my Stroboframe QuickFlip 350 and Nikon SC-18 cable
this week. Although I have not used it much, the bracket is very
well made and easy to handle. I am currently using it with an
SB-22s, and the bracket centers the flash nicely over the lens in
both portrait and landscape modes.
I have ordered an SB-28 because I want more power and more
flexibility in aiming the flash (the SB-22s flash head does not
swivel, but the flash can be rotated for bounce). Although a used
SB-24, SB-25, or SB-26 flash may be a little cheaper, I usually
don't buy used equipment unless I know where it has been. If money
is no object, get the SB-28 ($300). Most folks will be happy with
the SB-22s ($114). I have been using the SB-22s for over a year
and have been very satisfied with it. I probably don't really need
the SB-28, but now I will have a backup flash in case one ever dies.
If you get the SB-22s and the Stroboframe 350, you will need the
AS-E900 adapter to connect the flash to the camera. The cable on
the AS-E900 is not long enough to use with the Stroboframe, so
unless you want to splice the cable and add a few inches, you will
also need the SC-18 cable. You do not need the AS-E900 ($35) with
the SB24, SB25, SB-26, or SB-28.
Additional info can be found at:
http://www.panix.com/~donwiss/flashfaq.html
I bought the Stroboframe QuickFlip 350 ($44), SC-18 cable ($30), a
28mm UV filter ($10), and a StoFen Omni-Bounce ($17) at
http://www01.bhphotovideo.com/default.sph/FrameWork.class?FNC=StartLink__Aindex_html
I have been dealing with B&H Photo for over 10 years and have
always been very satified with their proces and quick delivery.
So basically what would you recommend?
I want the flash on the top of my 990 so what bracket would I need?
Also what cable do I need (if it does'nt come with the bracket)
Also would you recommend the SB-28 regardless if you dont use all
the features of the flash because of the 990?
Question for you guys ... I have an old SB23 Nikon flash. Will I need the ASE900 and SC-18 to mount this flash on the CP950??
