flash unit Recommentation
Samhamdesigns
New member
Upstate NY, US
Hello. New to flash, not to photography. This will be for Nikon Z5ii. This unit should be capable of TTL and manual, it should have a rechargeable battery and residual value as I grow. Budget is $300.00 Of course I've been poking around and it would seem that Godox might be a good place to start. I appreciate your comments and advice.
I’ve got three Godox V1 and one V1 Pro. The are Godoxex round faced Speedlights I like them but one reason I have four is they aren’t as well made as the Profoto A10 I like to have spares handy .
On the other hand you can buy three V1 units for the price of one A10. if the delta in price were smaller without compromising quality I’d have two A10s.
There are at least 4 suppliers of third party speedlights for Nikon cameras:
Profoto A10 is well outside your budget
Westcott/Jinbei FJ80 The SE version is well within your budget
Neewer Z1/Z2 is in budget and probably made for them by Godox
Godox Wide range of in budget choices:
iT20/iT22 small, inexpensive and not very powerful. Supports TTL but no radio not a good option
iT30Pro small, reasonably inexpensive not very powerful but supports radio as an external flash and as a trigger. Not a good option as the only speedlight but possible as a second one.
V480 medium power medium price device, well within budget may well be Godox's "Goldilocks" speedlight. TTL and radio send/receive
V860III High Power, large. conventional device. Only marginally more expensive than the V480. i wish there was a Pro version.
V1, V1Pro V100 All roughly within budget (you might have to shop around for the V100). Round head speedlights which take magnetic modifiers. V1 is roughly a V860 with a different head, V1Pro is a V1 with beefed up electronics which allows it to fire more shots before overheat protection kicks in. It also supports external battery packs. HSS support is improved. It has a fill flash which can be fitted to the front. V100 is a V1Pro with bigger capacitors and beefed up electronics which makes it a ~100Ws device rather than a ~80Ws one. IU is now a colour touch screen like the V480.
I think the sweet spot of these three is the V1Pro but others may differ.
Note I'm UK based so me comments on price reflect that.
As usual, Tugwilson is spot on. For what it's worth, I've been using a V100 with a Z5ii and it works well.
I was talking with another Nikon photographer on an assignment who loves the Neewer round head flash too.
Thank you for your comments and recommendations. I know just enough about flash to be dangerous to myself, so is there anything I'm missing about residual value; for example as I grow and need more power will the trigger compatibility be an issue?
I recommend the Godox V1. The Godox ecosystem is very large which means you have plenty of products you can add as you grow. You can use the Godox speedlight as a trigger for off camera strobes.
The round head allows using many inexpensive modifiers. I recommend the dome and filter. A CTO filter really helps balance strobe light color with typical interior lights.
The hot shoe attachment is DIY replaceable if it gets damaged and only costs $20.
I've been very happy with Godox for quite a few years now.
I like the tiny and lightweight TT350 to carry in my bag for use on camera, sometimes on its own, sometimes as a trigger for off-camera flashes. There is a Li-ion battery version if you prefer that.
All the popular Godox models work with all triggers, tho there may be some older models still in the market that are not compatible.
As already mentioned, they are not the best built flashes available, but they are so much cheaper that it is easy to budget for a spare.
Gato
Personal pictures, road trips, rural nostalgia, and kitty cats:
https://www.instagram.com/j.r.sprawls/
May I recommend some Strobist and NeilVN?
A used SB-5000 is about that.
  • Performance: Near-impossible to overheat (built-in fan), 67% faster recycle time than Godox V860III with an external pack, and only 0.3s slower without. Color-accurate to default flash WB.
  • Compatibility: Integrates with Nikon’s Unified Flash Control, works with shutterless Z cameras (no HSS banding), and supports future bodies without firmware issues.
  • Ease of Use: Uses common AA batteries, has a fast foot lock, and for off-camera the WR-R11a is lightweight, battery-free, and leaves the hotshoe free. It syncs bodies and works with the WR-T10 trigger.
  • Support: Nikon provides troubleshooting and repairs.
  • Rechargeability: I use Powerex - https://www.amazon.ca/Powerex-Capacity-Rechargeable-Batteries-2700mAh/dp/B06XDHM839
As you seem to guess and others have indicated, Godox has by far the largest and most flexible flash system, and it offers Nikon TTL units. Just be aware that there are also Godox TTL versions for several other systems, so make sure you get a Nikon version. IMO Godox build quality is good to very good for the price. But assuming you decide to get a Godox, a series of issues awaits you.
* It sounds like you probably don't want a what I might call a mini-flash, basically a shoe-mountable version of the flashes that have been built into many moderately-priced cameras. With rare exceptions, such flashes can't tilt or swivel, and don't put out much light. Godox flashes in this class are the iT20, iT22, and iT30.
* IMO especially because it doesn't sound like you plan to use the flash that much / that often, the choice between a flash that takes regular AA batteries--including regular rechargeable AA batteries, if you want--versus one that takes a dedicated lithium ion battery pack is an important one. As someone who can go many months between flash uses, I don't want anything other than one that takes AA batteries. In the Godox line, that basically means the smaller TT350 or the larger TT685 II. I have the latter and like it, but if you'd prefer somewhat smaller and the TT350 meets your needs, then it's also a capable option. Pretty much all the others take dedicated lithium ion battery packs.
* Among models that take dedicated lithium ion battery packs, some have roughly rectangular heads more or less proportioned like the image area, and others have round heads. Rectangular heads tend to be able to 'zoom' to cover a larger range of focal lengths, but many people think round heads offer somewhat nicer-looking lighting. The rectangular head models are the V350, which is a counterpart to the TT350; the V480, which is the newest; the V860 II; and V860 III. The round head models are the V1, V1 Pro, and V100. The bigger and more expensive ones tend to put out more light.
* A few of these flashes have modeling lights, albeit not very powerful. I think that's one of the step-up features from the V860 II to the V860 III. I think all the round-head flashes offer modeling lights.
Last and IMO least, I don't think any of the $300 flashes, Godox or Nikon or any alternative, is going to hold much residual value. Back in the day maybe a big Metz with a belt battery pack did, or maybe today a Profoto studio monolight would, but if you buy a new $300 flash, be prepared to get half that or less if you sell it in a couple of years.
In terms of being able to scale up from Speedlight to more powerful lights and stay with TTL capable triggers are flash gear there are 2 + .5 + .5 players players in the game
Both Godox and Profoto make lights ranging from hotshoe mount to 2400 w/s pack and head systems
Elinchrom is the first 1/2 player as the make a great line of battery and AC powered monolights and I believe their triggers can also work with their older and more powerful pack and head systems, but currently, no hotshoe mount flash
Jinbei/Westcott has the opposite problem lacks more powerful lights but does have a hotshoe mount flash.
Clearly the market today is oriented towards 100 w/s and lower hotshoe mount flashes and monolights that top out in the 500 to 600 watt-second range. That’s where the biggest market for electronic flash is. On the other hand I’ve had two jobs in the past two weeks where having a 2400 pack and head system (a 20-year old Profoto Acute 2 system) made all the difference in being able to do the job and with the quality of light required.
i spent most of my career (starting in the mid-1980s) as a single big lighting system user. Who also used speed lights when they were the right light for she job: . First Norman, then Elinchrom, then Balcar, then Paul C. Buff Einsteins, and Einsteins + Godox AD600 Pros. N the mid/late 90s, my assistant and I regularly dragged 12,000 watt-seconds of packs and heads. Once I had a job that doubled that (I was light g the interior of an Aluminum mill. And Speedlights from first : Vivitar, Nikon, and then Canon.
But these days I find myself n the unexpected but very flexible position of owning and using the 640 w-s Einsteins, the 2400 w-s Profoto Acute 2 system I mentioned earlier, an Elinchrom 3 monolight (which natively uses Profoto mount modifiers), a 600 w-s Paul C. Buff battery powered Celestial monolight, and 4 Godox V1 speed lights..
Along with my eye for composition, expressions, and detail, and experience at problem solving and directing people (both n front of and behind the lens, that technical flexibility is something my clients value.
Ellis Vener
To see my work, please visit http://www.ellisvener.com
I am on Instagram @EllisVenerStudio
All of this information and advice is immensely helpful! It's quite a bit to wrap my head around and I'm feeling a bit guilty; feel free to send me a bill! Just kidding of course but I really do appreciate it. When I get my ass in gear on this I will post some results. In the meantime Happy holidays!!
