Advice please
Cuka
New member
Good day.
This is my first time, so please be gentle.
For the years I use Sony RX100 lll. For all my needs. But now I should like to evolve and want to make myself clear is it worth to spend money at all.
This is something I did with my Sony and it is good enough.
But, when I make a detail bigger than resolution (or whatever) is bad, no sharp edges.
And this is what I should like to achieve. Or something close like this:
Please, be so kind to try to explain what is my problem. Not enough pixels, not good camera .....
Before spending money, shall I get significant improvement with better (expensive) camera?
Many thanks,
Daniel
These images are really too small to evaluate properly.
I do think you will benefit from an interchangeable lens camera.
Beyond the camera, better lighting and a good macro lens will make a big difference. Notice in the additional samples that you posted that lighting was arranged to help bring out the details. At least one, if not two light sources were used.
Your images were taken with 30 second exposures during which time slight room vibrations can add softness due to blur.
While a M4/3 or APS-C would be fine, I think a good macro lens on full frame would be the way to go. However, you need to research lighting as well. Choosing between a 24MP or 45-60MP camera will depend on how you wish to display your images.
I just answer with pics, original size.
For me, for my entertainment, it is important to have sharp edges after resize it, after enlarge.
Play with light and shadows is another issue, it is the matter of play and taste.
For really detail I use Sony DSC-T70.
Pure but very helpful cam.
So, at the end, what should be your recommendation. Without sale a kidney or even something more worth.
Dear John and Sherman, I appreciative your sugestions. Thank you.
Daniel
The RX100 III is indeed capable of very good images,
Those last three images appear to be expertly post-processed. There's nothing to indicate what kind of camera was used.
You can improve your results significantly by obtaining good post-processing software and learning how to use it. Here's an example of your original photo enlarged and processed to present better detail:
There are other steps you could take, but post-processing would still be important.
I took your 2nd image and processed it 3 ways (top left, top right, bottom left) in Topaz Sharpen. The bottom right section marked "not updated" is your original. It's a screen capture, displayed at 100%.
You can see the full size. image by tapping "original size" and clicking on the resulting image until the + in the cursor is no longer visible.
You can also just click on the image and then tap the "100% zoom" control.
Does this help?
Sherm
Sherms flickr page
P950 album
P900 album RX10iv album
OM1.2 150-600 album
What's your entertainment budget? A movie ticket, or a trip for an African safari? :-) A high-resolution camera (>40 megapixels) with a macro lens and accessories (tripod, focusing rail, multiple lights, lightbox) would be a very nice setup. Some cameras have focus stacking and pixel shifting functions built in.
But to start with easy things, look up the photographic terms "diffraction" and "focus stacking". Here are a few nice tutorials:
What Is Lens Diffraction? (see section 4 about sensor size*) Try a shot at f/4 and see if image sharpness at the focus point gets a bit better.
Focus Stacking Tutorial for Landscape Photography (also relevant for watch mechanisms)
How to Focus in Macro Photography (see the elaborate focusing rail setup in section 3, simpler rails are available)
If you aren't shooting in RAW mode, consider trying it. RAW file developer computer software, like Sony's free Imaging Edge, gives the user more control over the sharpening process. Your camera's built-in RAW file developer, the JPEG engine, uses a generic sharpening process optimized for speed and efficiency.
*From other references, diffraction for a Type 1 sensor becomes a consideration somewhere around f/4 or larger (f/5.6, f/8, etc). You're shooting at f/11!
Lance H
Ditto the f11, diffraction has definitely set in resulting is a softer image.
The first two are much better, with better lighting. You can see how smaller apertures give greater depth of field opposed to the image taken at a large aperture. Focus stacking can be used to give more depth of field but I am not sure how well the process would work with these very precise machine parts. I'd do some research on focus breathing with macro lenses. When I googled the Sony Macro there were a bunch of watch images that were taken head on which makes depth of field much easier to deal with. Using a Macro lens likely means getting closer to your subject which again reduces depth of field. All sorts of challenges to respond to.
The list of possible camera/lens combos is very lengthy. Assuming a tighter budget I would buy used to maximize your budget. To stay with Sony and mirrorless I would start with the Sony A7R II. To maximize your budget with Canon and Nikon I would start with a DSLR. Canon possibilities are 5D II, 6D II, 5DIV and 5DSR. Nikon possibilities are D800, D810, and D850. I specifically avoided a few since their relative values are less effective.
Lenses could then be Sony 90/2.8 Macro, Canon EF 100/2.8 or 100/2.8 L, Nikon 105/2.8 Micro or a Tamron 90/2.8 Macro. Not sure which ones reach 1:1, and if extension tubes are required.
Alternatively you could start out with a vintage macro lens from Nikon, Canon, or Tamron with manual focus. There are different ways of doing this on each different camera. Tamron is the only third party manufacturer that I have included since their 90mm has been well respected for fifty years.
If I can find an appropriate subject I will try to give you an idea of the possibilities.
Dear friends.
It is easy to ask right question when you are familiar with something. The same happen to me here. I am not in photo at all so my understanding and knowing terms is almost none. It seams that, as any other, there are no simple answers for ignorant as me.
At the end it seams I need no macro at all.
And thank you for your thoughts,
Daniel
Dear friends.
Daniel
Well, taking good photos needs learning and practice. It's like learning to play a piano or learning how to cook well. :-(
The simplest way would be a straight down shot like this with the camera set to f/4 or smaller (f/3.2, f/2.8, etc). Try it!
data:image/jpeg;base64,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
Lance H
