If you want a compact Full Frame with a fast lens and reliable autofocus, there is NO alternative to the RX1Rii/iii.
Every "Alternative" is either a lot bigger, or has a much smaller lens.
Smaller is not always better
Anyone thats considering the RX1Riii, probably has size near the top of their list of most important things.
If this were family feud, the top 3 answers would be:
- Size/pocketability
- Full Frame sensor
- Zeiss lens
I have no idea what 'family feud' is but I would agree with these three strengths.
For me though it is too small which doesn't help handling and it can make it harder to use at lower shutter-speeds.
If you dont understand why people want the size of the RX1R, then you dont understand the RX1R. The small size is its reason for existing. If you disregard the size, the A7CR is better in every way. (They both have the same EVF)
What I disagree on, are the Leica Q3 and the Ricoh GR. Aside from the size differences, they have worse and even worse AF. And the Ricoh GR has a slew of other negatives.
And about stabilization, its nice to have. This is a 35mm lens, without shutter shock and without a mirror slap. Its pretty easy to get sharp 1/60, and 1/15 with some concentration.
-keep in mind that I do have a wood grip taped to my camera. Makes it a little easier to hold.
What makes you say the Sony has better AF than the Q3. Is it personal experience.? I have been very happy over two years with a Q3. Note that I don't use the subject-detection modes etc.
How can you say the Q3 has a better EVF than the RX1Riii? Do you own both?
I own one and have handled the other a fair bit. Few would argue that the Sony EVF is close to the Q3....
how can you say the A7C is better than the RX1R?
Because it has stabilisation, ergonomics and battery-life.
How can you recommend a Ricoh GR or Fuji X100.... have you used those cameras enough to be comfortable recommending those cameras?
Yes, I have owned both these camera and used them extensively.
Simply put, you dont have to own everything to form an opinion on it. You can watch/read reviews. No unbiased reviewer would put the Q3 AF on par with a the AF of a newer Sony Camera.
I am sure AF-S works great on the Q3, but my Sony A850 was also great with AF-S. But how is it when you use AF-C, or subject tracking?
I said din my post I don't use tracking etc. nor do i use AF -c. Sony AF S and tracking will be better as I acknowledged earlier. It is not a sports or wildlife camera though of course but it maybe important to some I suppose.
The default as setting is 1/125 seconds which suggests real-world usage. Q3 is around 1/15sec.
I am not arguing that the Q3 stabilization works. My point is, do most people typically handhold shoot at 1/15? The RX1R can do 1/60 without issues. 1/15 works, with concentration.
Yes is I handhold at a lot at slower speeds e.g building interiors. I have taken thousands of these types of shots with various setups.
And as I said earlier, missed focus is much worse than a minor amount of shake.
In two years I had to switch to manual focus 3-4 times.
Adding the necessary grip will make the Sony bigger of course.
Did you see the picture I posted? MY grip does not add a single MM to the width or height or depth of the camera.
Noted.
The OP I believe chose the AC7 in the end...
