homebodyMacro
Forum Enthusiast
- Messages
- 444
- Reaction score
- 483
Hmm, honestly have never used the brush, but in the top left of the editing view (can be slightly outside the image if you aren't zoomed in far enough) it has feathering/size options if you want to use that to refine your mask. From checking PL8, it appears to have been the same menu there.Thanks for this!Honestly, I don't know that there's a huge learning curve for it. If the subject selection isn't totally working on first point, you can move the point, or add a few more points and it seems to get it.OK, I just gave the PL9 AI Masking a whirl. I thought it was pretty snappy actually, considering my video card was at minimum spec (RTX 2060 w/ 6GB). I didn't really have to wait a long time for anything to render.
I'll have to watch some tutes to become more proficient at the masks though!
Here's an initial Auto Mask...
I see lots of potential here. :-D
R2
You can also right click and invert the selection, then select more points if needed for the inverted space (where the subsequent points are not themselves inverted).
You can also duplicate a mask as well, where I feel like the main use would be to invert the overall mask that you just made (in some cases it's easier to select an object and invert than select everything besides the object).
Certainly I'm interested in what others come up with, but that's the basic functionality that's present at the moment.
Honestly, I think I'll use this functionality quite frequently. I definitely need to invest in some more lighting implements, but in most cases with nature or action, exposures are imperfect and masking can have a major benefit for fine-tuning on the subject(s) (and in special cases like I mentioned above, with depth-based smoke/haze blue-shifting of images). The upgrade was about $120, and considering it will have a moderate to major impact on a lot of photos, well worth it imo.
Also as far as color/tone etc., in my experience with some tests the R5II camera profile in DxO PL8 (and PL9) on various tests I did was essentially a perfect match to my AWB-white priority picture style photos straight out of DPP4. I think Canon/DPP4 do a great job with colors/AWB, so having a functionally identical profile in DxO is exactly what I wanted.
I did figure out how to add and subtract (hold ALT) to the mask using the brush, but I haven't figured out how to resize the brush or change the hardness/feathering. This is just from 5 min playing around, so I know there's more functionality hidden in there! :-D
R2
With that, I now notice that the AI mask has the same menu, though the options are point vs. area selection (area selection doesn't seem to be showing me the rectangle I'm creating, but it seems to have worked really well on my test just now). After restarting though, it does show a rectangle lol.
There's also an option where you can ask it to scan the image for a specific subject, which could be useful for plenty of cases.
I have had a few cases where it has thrown an error: "Internal error (correction failed on the Excecute stage)". It seemingly needs to restart after this. I haven't had it happen on the normal point selection, but had it happen after it didn't find a subject for me (butterfly not under animal I guess).
Unsurprising that there are some bugs that will be worked out. I will say, the area selection on my butterfly test definitely gave a better selection of the fine details (slightly out of focus antennae and legs) vs. point selection. So that will be a worthwhile option in some cases.
Glad you mentioned this - I have large monitors and might have missed the options until a later time. Seems like the subject type detection algorithm is a bit crashy at the moment though (and failed to detect more obvious animals for me also), so probably best to avoid. I will say, PL9 seems to boot faster than PL8 though.
