sirhawkeye64
So, if I used a 24-200 @ 200mm let's say on a Z8 at 45MP and then downscaled the image to 24MP dimensions (say 6000x4000) while maintaining aspect ratio and no other adjustments (like sharpening) would the rescaled image look similar to that if it was taken on an actual 24MP sensor?
Reason I'm asking is because I'm contemplating using a 24-200 on a Z8 for my upcoming trip but I know a lot of people say the lens is better suited for the 24MP sensors (likely because it's soft at the long end, in the corners/edges of the frame). However, using it on the Z8 does also give me some other advantages I might not otherwise have if I used my Zf (24MP). Particularly, I'm not so sure about upscaling a 24MP image taken with this lens to say Z8 dimensions (so 45MP) but would possibly downscale the image to 24MP if needed.
(I'm sort of trying to figure out which body I should really take, as both has their advantages, and I have done some larger prints over the past few months but those required scaling using Gigapixel, but I also shot them with a Z 24-120 which is sharper than the 24-200. And yes I am aware of the technical differences bewteen the two cameras -- low-light AF, DR, ISO, etc. This is more related to output using the two cameras and different methods for scaling images.)
* PLEASE NOTE: I generally unsubscribe from forums/comments after a period of time has passed, so if I do not respond, that is likely the reason. *
