John Bean (UK)
I thought I'd give this a try (it's cheap!) but the one I got has problems with the IBIS on my X-T50, behaving much like a manual lens does if the focal length setting is wildly wrong - it's actually better with the IBIS turned off.
The lens works fine otherwise and the EXIF data shows the correct focal length so I'm guessing it's a lens firmware issue - and currently there are no updates available. Optically it's not great but neither is it terrible - as long as you keep the shutter speed high enough or disable IBIS altogether.
I have its brother the AF 27/2.8 that works perfectly on the X-T50 and despite all of its little idiosyncrasies I quite like it, so I was hoping the new 14mm and existing 27 would make a handy pocketable pair. But the IBIS issue is a show-stopper given the aperture of the lens, making it unusable except in bright light.
I've returned the lens as faulty but I'm posting this mainly to inform anybody looking at this lens that it might be a design/firmware issue rather than a faulty sample, so if you rely on IBIS for slow shutter speed hand-held shots it may not be a good choice.
