Hello all,
I am shooting with a Sony A7CR and Fe 24mm F1.4. I am not good with the math side of things so I asked Chat GPT. Basically I am trying to figure out the cropping percentages of a photo to mimic 35mm, 50mm and 85mm focal lengths. My camera has a lot of megapixel so it is still producing 4K images after cropping over 100% in post. I am hoping for those of you who are very knowlegeable in this area and the calculation side of things can take a look at the info below and comment on how accurate and correct this is. If this is true, I might not have to buy all these lenses in differenct focal lengths. I understand that the background blur and/or compression looks will be different between cropping and using lenses with actual different focal lengths. Thank you in advance.
Here is what Chat GPT gave me:
To estimate how much cropping is needed to match different focal lengths on your Sony A7CR with the Sony FE 24mm f/1.4 lens, we need to compare the field of view (FOV) provided by each focal length relative to the camera's sensor.
Camera details:
The crop factor for full-frame cameras is 1x, so the field of view is directly proportional to the focal length.
Equivalent cropping percentage:
In practical terms:
A7CR + FE24F1.4
Camera details:
- Sony A7CR sensor size: Full-frame (35mm equivalent)
- 24mm (your lens)
- 35mm
- 50mm
- 85mm
- To get a 35mm view from 24mm, you need to crop approximately (24/35) ≈ 0.686, which is about 68.6% of the original image.
- So, around 31.4% cropping of the original image to simulate a 35mm view.
- For 50mm, cropping ratio from 24mm:
- (24/50) = 0.48, or 48% of the original image.
- 52% cropping needed.
- For 85mm:
- (24/85) ≈ 0.282, or 28.2% of the original image.
- 71.8% cropping needed.
In practical terms:
- Cropping from your 24mm image to simulate 35mm means cropping out roughly 68.6% of the frame.
- To simulate 50mm, crop about 52%.
- To simulate 85mm, crop about 72%.
A7CR + FE24F1.4
