I periodically go though panoramic photography phases and after several years I feel one coming on again. I have a dp0 Quattro for tripod mounted landscape, but I’ve personally found using it handheld to be a nonstarter.
I’m wondering if a sd Quattro with a 14mm might work for me as a handheld panoramic camera. It has the same 21:9 aspect ratio available with a choice between transparent and opaque framelines as does the dp0.
I’m thinking the sd Quattro would do better for me than the H model, a 18mm-e would be a little wide for me. Are there major differences between the two models other than sensor size? If I scratch this itch, would I do better with an H variant?
