T-Rex Mark
- Messages
- 1,130
- Reaction score
- 1,057
Sooo, I knew that this may have challenges but at the same time I was hoping for a miracle. The puzzler is a CZJ Cardinar likely taken off Werra and then modified with an exacta mount slapped in place of what was there. The mount works fine but the aperture is stuck almost :-( wide open. I would not be as bothered if it was wide open, it’s only closed perhaps to 4.8 but enough to modify the circle.
anyone has an idea of how to disassemble this creation?
I took the three screws from the mount and the little guy serving as Exacta stop - the mount sits really tightly - after I took the screws it did not feel like anything is letting go at all. I really just wanted to open the aperture and perhaps get to the helicoid as it is a little tight.
Taking these three little bolts out has not loosen anything
I thought the little lever would move the aperture but it does not give at all when I try to push it with screwdriver
here are a few shots in dim sunsetting light - pardon longish handheld exposures
It is not in perfect shape needless to say but i find this an interesting challenge and I like what it produces. Also, for the 100mm it’s an incredibly small lens, I will read some more on it, wonder what is the design.
If anyone has any idea on its construction - please let me know.
edit: found this video for the original (and very clean) lens. The little lever seems to be the aperture lever. I am thinking that perhaps the mount somehow presses on aperture mechanism. Also it appears that aperture does not open all the way as this video shows it visible when wide open
looking at other images it does look like wide open os not fully wide open https://www.ebay.com/itm/235702600992
still no idea how to take the mount off but considering this is wide open I am less concerned although I will likely try to figure it out to lubricate the helicoid
https://500px.com/bc-foto
