Most lens greasy finger marks come from putting lens caps on and off. If employing a reasonably deep lens hood then usually there's no need for the lens cap, hence way less (or zero) finger smudges. Any loose dust is easily shuffled off with a rocket puffer or micro fibre cloth.Hi all.
With all my lenses I got a lens hood. Bit I never use them.
Do you use yours and if so what for?
Cheers
Woody
How does a hood protect from water?Yes. Foremost for flare control second, protection from debris, water, physical damage.
You might not notice that a hood can improve the contrast. It is useful for SOOC shooter. It could also save you some editing work even if you would edit your output.I stopped using lens hoods many years ago. Too cumbersome.
As far as flare - I rarely encounter it, and when I do with the sun at a sharp angle, I just put my hand up to block it.
I swap lenses a lot. Hence, I would uncap every lens, both the front and back cap (and put on the hood), when starting a shooting session. This can speed up lens swapping by >50%.As far as protection for the lens - after making an exposure, I replace the lens cap. The most secure protection, IMO.
It definitely helps to reduce cleaning of finger print on my lensesI just now looked at my Panasonic 20mm, 14-45mm, and 45-150mm lenses - among my first lenses some 15 years ago, and the front elements show no damage.
When I required to swap lenses within few seconds nearly on shot to shot basis (the fun to use ILCI don't know why one would touch the lens "with greasy fingers" as one person wrote.
-richard
I rarely use lens hoods (except for the very long focal lengths) as they are just too much bulk and bother. For photos taken with the sun shining onto the lens, I generally find some other way of shading the lens from direct sunlight. I find that works for me, but it wouldn't for everyone.Hi all.
Cheers
Woody
