Thanks,That’s correct. The F100 can only use lenses with an electronic aperture (E lenses) wide open and can’t use AF-P lenses at all.
The very last generation of F-mount lenses with the E rather than G designation started to use electronic aperture control for higher FPS shooting rather than the classic lever design.Thanks,That’s correct. The F100 can only use lenses with an electronic aperture (E lenses) wide open and can’t use AF-P lenses at all.
But then why are the apertures of the first 2 lenses closed?
Is there any list of the compatible lenses? I only found Ken Rockwell's camera/lens compatibility list that basically say that everything works except for the AF-P (which I don't care about)
anything that isn't AF-P or isn't an E lens will work.Thanks,That’s correct. The F100 can only use lenses with an electronic aperture (E lenses) wide open and can’t use AF-P lenses at all.
Pretty sure the F6 can't operate E lenses.Hi,
Yep. You do realize that the F100 is a film camera?
As such, it's age becomes immaterial. The only thing newer is the F6.
That leads to a question. Does the F6 operate E lenses? That's the last film body.
Stan
Yes. I have one sitting on a shelf in my library. It was a great camera but I haven't used it in many years.Hi,
Stan
This is correct unfortunately. :-(Pretty sure the F6 can't operate E lenses.Hi,
Stan
My D2X is newer than the F6, and it can't. I think the first cameras that were able to do that were the D3 and D300 in 2007
The F6 is from 2004 and as such, can't control the aperture of E lenses, and can't shoot AF-P lenses at all.
oh, thank you!Hi,
The apertures are left where they were set last. So you need to put the lens on a camera that supports them, open the aperture up, then remove the lens and put it on your F100. The aperture will stay wide open.
That's the same as with my F5. I choose to simply avoid buying E lenses so I don't accidentally try and use such with my digital F5 which I do still use every so often.
Stan
Here's another trick with E lenses on older cameras.oh, thank you!Hi,
Stan
I didn't realize you can open the aperture this way and I just tested it - the (modern) camera has to be ON for this, otherwise it closes the aperture of an E lens when you turn it OFF and then you end up with something that won't even lock focus on F100.
But it's great to know I can now use my 105 f1.4 on F100 wide open!
Thanks for the constructive feedback from everyone! Most of my lenses are normal so they work fine with F100 and now I also know how to use my E lenses wide open - amazing! - and I'm happy I didn't buy a faulty camera![]()
