Hi all
I've been using this gimbal for almost three years. It's not fully compatible with the ZV-1 as far as controls are concerned but the stabilization has worked fine until recently. I do my shootings either walking or sometimes riding my bicycle. The results have been excellent. Now after a couple of minutes the videos present a terrible shaking on the vertical axis. Neither the amplitude nor the frequency are important but it completely spoils the video. It's hardly noticeable while shooting. I had to trash all the recent videos I did.
The cam an the gimbal are cable connected, not by BlueTooth or WiFi.
I made no change to the settings.
I keep both gears fully charged.
I have a fairly firm hand: I don't shake and I always make soft and progressive movements. Until recently the gimbal stabilized quite well my movements even during extended shootings: from 30mn to one hour (in several consecutive sessions).
I made different tests:
I put the combo on a tripod and did a static shooting. Nothing wrong happened. Since the issue happens only while I am on the move with the gimbal in my hand I suppose it's the gimbal's reaction to movements, especially panning, that are not OK anymore.
I also put the ZV-1 on a tripod and did a static shooting. Nothing wrong happened either. So it's not in the cam.
I suspected a faulty data transmission between the two. But then why does the issue happens after a couple of minutes?
Do you have any clue, folks?
TIA
Nick
TIA
Nick
