It does seem to be noisier than the R5
DPR comparison
jj
I downloaded the Raw Files for the R5 and R5mk2 at ISO 6,400 and 128,000, and the lighting is quite different between the pictures.
For example, look at the aluminum paint tray in the bottom right corner and the bottles in the middle of the bottom. In the R5 Mk 2, the aluminum paint tray is gray, whereas on the R5 Mk1, it is almost white.
Looking at the gray in the center of the picture
the R5mk1 is about 0.5 stops brighter than the R5mk2.
The R5mk2 has much more contrast than the R5 in the overall picture. I reduced the R5mk1 by 0.5 stops to "normalize" it to the R5mk2, and still, the darker gray on the outside is much lighter than the same area in the R5mk2. Also the "gray" in the center of the R5m2 is off the red and blue a bit.
It is hard to compare noise when the pictures are different in lighting, white balance, and contrast.
I'm not complaining about DPReview's method, as I know they are trying to make an objective comparison, but it is tricky to get the exact same shot about 3 years apart.
I'm just suggesting that this is not a definitive result.
BTW, on the ISO6,400 shot, I also looked at the Sony a7R picture, and its exposure was about 0.5 stops darker than the R5mk2 or a full stop darker than the R5mk1.
