Pseudophotographer
Active member
- Messages
- 74
- Reaction score
- 92
What do you think are the 3 essential lenses for your Panasonic Lumix S5II or S5IIX and which sooner or later will you end up buying?
and.... why?
and.... why?
Canon EF 16-35 f/4 L ISWhat do you think are the 3 essential lenses for your Panasonic Lumix S5II or S5IIX and which sooner or later will you end up buying?
and.... why?
Has the latest firmware update to the S5 ii (embodied also in the S9) eliminated the wide-angle wobble using IBIS?Canon EF 16-35 f/4 L ISWhat do you think are the 3 essential lenses for your Panasonic Lumix S5II or S5IIX and which sooner or later will you end up buying?
and.... why?
Canon EF-S 10-18 IS STM
Panasonic 24-105 f/4
The main reasons for these lenses are for the lens-based image stabilization (IS, as canon calls it). This greatly reduced corner "wobble" when shooting video at ultrawide angles.
I don't know of any native ultrawide L-Mount lenses that have stabilization in the lens itself.
Also, since 4K 60p is cropped, you again need something very wide, and again, no native lenses with lens-based stabilization works.
The 24-105 f/4 is a good all-around lens (as long as yoiu don't get element separation, I guess).
If you had been more specific, I might have picked different lenses, just so you know.
S 28-200. Absolutely excellent and versatile all-in-one, obviously except for really shallow DoF portraits and ultrawide. I use it 99% of the time.What do you think are the 3 essential lenses for your Panasonic Lumix S5II or S5IIX and which sooner or later will you end up buying?
and.... why?
1. Lumix S 28-200mm f/4-7.1 MACRO O.I.S.What do you think are the 3 essential lenses for your Panasonic Lumix S5II or S5IIX and which sooner or later will you end up buying?
and.... why?
If I understand correctly, you lose enough of the image that you are no longer shooting ultra wide. There is a pretty big difference between shooting 16mm and shooting 19mm or more.Has the latest firmware update to the S5 ii (embodied also in the S9) eliminated the wide-angle wobble using IBIS?
Here is what Panasonic says about the additions from the newest firmware:
If it does, the now one can use native lenses, which are smaller without an adapter or IS.
- "Enhancement of Image Stabilizer performance.
•A perspective distortion correction has been added to correct distortion that tends to occur during video recording when using a wide-angle lens."
and.... why?
It's an issue that happened to a couple of lenses of the first batches. But not only to the 25-105, also to the 50/1.4. but that's also nothing brand special. It also appears with lenses from other brands...Canon EF 16-35 f/4 L ISWhat do you think are the 3 essential lenses for your Panasonic Lumix S5II or S5IIX and which sooner or later will you end up buying?
and.... why?
What is the element separation issue on the 24-105? Something it’s known for I’m assuming. Is it something you’ll know you have an issue with when you first get it or is this something that happens over time?
Probably thats about that issue.I keep seeing references to the panny lenses not being the greatest quality. Issues with the 50 1.4 etc…
I think most Panasonic lenses have indeed exceptional image quality for there specific price regions. The 50/1.4, 50/1.8 or 85/1.8 have excellent image quality. Better than most compatitors for similar pricing.Most don’t seem exceptional in imaging either. Shame because I love the size and usually the focal lengths and overall design choices. More control functions on them would be nice.
35mm APO SL F2What do you think are the 3 essential lenses for your Panasonic Lumix S5II or S5IIX and which sooner or later will you end up buying?
and.... why?
What do you think about he new Sigma 24-70mm f2.8 Dg Dn II?35mm APO SL F2What do you think are the 3 essential lenses for your Panasonic Lumix S5II or S5IIX and which sooner or later will you end up buying?
and.... why?
50mm S Pro F1.4
24-70mm S Pro F2.8
They are the reason why I use L mount.
I agree every mm counts for ultra wide angle. That's why I selected the Lumix 14-28 lens.If I understand correctly, you lose enough of the image that you are no longer shooting ultra wide. There is a pretty big difference between shooting 16mm and shooting 19mm or more.Has the latest firmware update to the S5 ii (embodied also in the S9) eliminated the wide-angle wobble using IBIS?
I am glad you asked.Hi, why both Canon’s? They cover the same range on FF?Canon EF 16-35 f/4 L ISWhat do you think are the 3 essential lenses for your Panasonic Lumix S5II or S5IIX and which sooner or later will you end up buying?
and.... why?
For those two Canon lenses (the 16-35 and the 10-18), the image stabilization works brilliantly. I don't own any ultra-wide Panasonic lenses, but from what I have seen shot on, say, the Panasonic 20-60, the combination of lens stabilization (in the Canon lenses) and the body stabilization (reduced to two axis when using a lens with lens stabilization) is SIGNIFICANTLY better (at least in terms of video, and more specifically, when walking / moving while shooting video).I always wondered how a a non-first party lenses IS would work when not being used natively. I guess it’s not an issue.
Well, I only own the first-generation of S-series cameras (an S1 and an S5 MK 1), so, NOTHING focuses well on them.Does it focus well adapted?
There are a few threads on this forum about lens element separation on the 24-105 f/4 and the frustrations people have had getting Panasonic to fix the issue. I suggest you search for them.What is the element separation issue on the 24-105? Something it’s known for I’m assuming. Is it something you’ll know you have an issue with when you first get it or is this something that happens over time?
I only have the 24-105 f/4, and mine has been pretty good (except for the above focus issues, but that has more to do with Panasonic's legacy autofocus system.I keep seeing references to the panny lenses not being the greatest quality. Issues with the 50 1.4 etc…
Well... it depends. Some people LOVE their sigma lenses for sharpness and contrast. But if you are using your camera for shooting video (something Panasonic WANTS you to do), then things like the consistent size, filter size, and center of gravity are all really beneficial.Most don’t seem exceptional in imaging either. Shame because I love the size and usually the focal lengths and overall design choices. More control functions on them would be nice.
Truly, the bundle deals that Panasonic offers on the S5 II and S5 IIX are hard to beat.Hard to pass up on current prices though, so bang for the buck is high.
I think the points you make in the above statements are all true.I love how Panasonic continually adds with firmware, has nice menus, and a lot of features. The Leica aspect of L mount isn’t that much of a boon for Panasonic as most won’t be buying those lenses, and Sigma isn’t competing in cameras, at all, and I say that as someone with a DP2M and would love to see the FF Foveon happen, which it seems it will, but they said it’s years away.
So, for many, L mount is really just Panasonic with Sigma and Samsung lens availability.
I do hope it continues to progress, I really like what Panasonic and Sigma do as companies.
sorry I’m a little off-topic, I’m just looking at buying in with and S5II with the current EDU deals.
The Panasonic 14-28 would certainly be a MUCH better option for the majority of Panasonic / L Mount shooters than trying to adapt the Canon 16-35 f/4 (although the Canon lens IS a Darn Good Lens).I agree every mm counts for ultra wide angle. That's why I selected the Lumix 14-28 lens.If I understand correctly, you lose enough of the image that you are no longer shooting ultra wide. There is a pretty big difference between shooting 16mm and shooting 19mm or more.Has the latest firmware update to the S5 ii (embodied also in the S9) eliminated the wide-angle wobble using IBIS?
What are those situations? I can maybe test out the performance of the 14-28 (on the S9). There are now many stabilization options, including regular IBIS, IBIS boost, and electronic regular and electronic HIGH.Unfortunately, the 14-28 wasn't available when I purchased the canon lenses (like, four years ago or so, I recon).
It MIGHT replace my Canon 16-35 eventually. Just I would love to see how well it works in the types of situations I am more likely to use it.
Thanks for your offer.What are those situations? I can maybe test out the performance of the 14-28 (on the S9). There are now many stabilization options, including regular IBIS, IBIS boost, and electronic regular and electronic HIGH.Unfortunately, the 14-28 wasn't available when I purchased the canon lenses (like, four years ago or so, I recon).
