Stevie Boy Blue
Due to its already wide reaching and increasing popularity as much as its reputation for producing vibrant, colourful images with beautiful contrast and great resolution, this lens hardly needs any introduction.
The renowned popularity of the Panasonic Leica 12 – 60mm F2.8 – F4 largely speaks for itself, but just how good is it and, perhaps more importantly, is it worth the extra money compared to the Panasonic F3.5 – F5.6 version that generally comes much cheaper?
Right off the bat, for me the answer to that question is a resounding YES. In my experience of having used both, there are noticeable bonuses for selecting the P L over the P version. And, of course, there probably should be because of the Leica association alone. Yes, all these lenses are made and assembled in the Panasonic factory, but the premium quality that comes from Leica’s input at the design and development stage is evident – not just in relation to overall build but in terms of output, too.
Don’t get me wrong here, the Panasonic only version is a good lens and represents a real bargain at less than half the price of the Leica. If it matters to you, the Panasonic version’s noticeably lighter and smaller, too. And in my experience the output of the F3.5 – F5.6 is good for the price we pay. It’s just that in every way barring the increased weight and size (for me), the Leica 2.8 – 4 is an improvement.
For starters, the Leica zooms in and out more smoothly. It’s better built, albeit perhaps no more shower and dust proof than the less expensive version. (The fact that both are weather-sealed to some degree is a welcome bonus that I really appreciate.) But in terms of use and output, I’d say we definitely get what we pay the premium price for. All you have to do is re-read my opening paragraph above to comprehend where the most important differences can be found courtesy of the better glass, faster apertures and likely improved lens coatings found in the more expensive product. If, and I emphasise ‘IF’, you can afford the extra cash and are able to put up with the additional weight and bulk over the Panasonic version, the Leica is the better option in my view.
PERFORMANCE & IMAGE QUALITY
In an attempt to aid some readers who may appreciate knowing in advance, I’m setting out below how quickly and at what points along the zoom range the aperture gradually closes from F2.8 to F4.0 re the P L 12- 60 lens in my preferred shooting setting of Aperture Priority:
12mm F2.8: 13 to 14 mm F2.9: 15 to 16 mm F3 – F3.1: 17 to 18mm F3.2: 19 to 23mm F3.3 – F3.4: 24 to 26mm F3.5: 27 to 32 mm F36 – F3.7: 33 to 50mm F3.9: 51 – 60mm F4.0.
Note that I shoot only Jpeg in the fine quality setting in Standard Colour Profile. Hence any corrections of lens distortion to a large degree are performed by the in-camera jpeg engine. From what I see, purple fringing and CA are very well controlled to nonexistent.
Except for the extreme corners, which soften slightly at 12 mm F2.8, the lens is generally sharp wide open and across all focal lengths and especially at the centre of the frame. When necessary, I’m more than happy to shoot wide open and am more than pleased with the sharpness overall. As with most lenses where it’s available, however, I find things sharpen up a tad more at F4 even at wide angle, and they remain that way up to around F14.
I find F4 to F9 particularly pleasing for landscapes and architecture from wide to mid focal range. And I’m impressed by how the lens lends itself to makeshift portraits at F4 full 60mm zoom – especially in good daylight. I even tested it briefly in a studio environment with no extra lighting beyond what was available from the nearest window. Admittedly ISO requires a bump up to compensate for slower shutter speeds under such circumstances. But if and when push comes to shove and we have no other option with us, the PL 12 - 60 is more than passable for the purpose seen in the appropriate Portrait example of the model below. (Image No.9.)
Note that Full Lens Specifications, including size and weight, etc., can be viewed here:
https://www.dpreview.com/products/p...ic_leica_dg_12-60_2p8-4p0_asph/specifications
At the time of writing this review, Panasonic’s latest firmware update, version 1.5, for what is known as the H-E12060 lens was released February 21st 2024, a direct link for which safe download is available here for anyone requiring an update: https://av.jpn.support.panasonic.com/support/global/cs/dsc/download/fts/dl/es12060.html
PRICE and CONCLUSION
Notably, whilst the lens alone costs around £799 RRP, it’s often bundled as an offer when bought with a new body such as the G9 Mk2. When obtained in this way by those in the market for both a camera and lens, savings of £200 or more can be made on the combined total price. Good deals can also be found in the used market where, if we’re lucky, near brand new P L 12 – 60s where kit buyers have split the lens from the body and are selling it on can be found for around £400.
Unfortunately, I bought my copy just before the G9 Mk2 was announced and I paid full RRP minus the trade-in allowance for my Panasonic 12 – 60 F3.5 – F5.6. I just didn’t see the point in owning both. Had I waited just 3-weeks or so longer, I could have made a saving on the G9 II Kit. Still, I’m very happy with the performance of the lens, whether I couple it to either of my two G90s, the G9, G9 Mk2 or G100.
Paired with the G9 or G9 II, I obviously notice the combined weight far more than when using it on my G90s and especially the smaller G100. As we might expect and appreciate, the P L 12 – 60 comes with built-in lens I S, which, if added to a body with IBIS, Dual IS function’s enabled by default. Although the G100 lacks IBIS of any kind for stills, the lens I S is more than enough for me to keep things stable with this smaller body. As for AF speed, that’s very fast with any of the bodies mentioned above. AF accuracy is great and very reliable, too.
Bottom line, this is a fabulous, generally sharp and very versatile do-it-all lens with great contrast and wonderful colour reproduction. Hence, I recommend it with no reservations beyond the fact that it’s slightly heavier and bulkier than I’d like it to be. No wonder it’s become so popular and well respected since it was originally released a few years ago. It’s already a true classic in the eyes of many who own a copy – and rightly so from my experience.
Image examples cropped/resized for faster uploading. All were shot as Jpegs:
Shot using only available light from nearby window. No artificial light or flash assist with G9 II.
Thanks very much for reading.
PS: For anyone interested: Since joining DPR in 2009, I’ve compiled various user-reviews intended to help readers by giving them some insight into my favourite Panasonic products, links for which are supplied below. Please note that I use my time freely and completely absent of remuneration or freebie goods from anyone or any company. If a product impresses me enough, I enjoy spreading the word. I speak as I find and I just happen to like Panasonic cameras and lenses more than any other makes. That’s why I buy and recommend them – nothing more, nothing less.
Panasonic G9 Mk 2 Camera: https://www.dpreview.com/forums/post/67372017
LX100 II Camera: https://www.dpreview.com/forums/post/67207832
Panasonic G9 Camera: https://www.dpreview.com/forums/post/66941383
LUMIX GX 45 – 175mm PZ Lens: https://www.dpreview.com/forums/post/66935382
Lumix G100 Camera: https://www.dpreview.com/forums/post/65550733
Panasonic 25mm F1.7 lens: https://www.dpreview.com/forums/post/66591863
Panasonic 42.5mm F1.7 lens: https://www.dpreview.com/forums/thread/4665967
Panasonic 14-140mm ii lens: https://www.dpreview.com/forums/post/65695092
FZ2000 Review Part 1: https://www.dpreview.com/forums/post/64288303
FZ2000 Review Part 2: https://www.dpreview.com/forums/post/66360652
FZ300 Review Part 1: https://www.dpreview.com/forums/post/63244070
FZ300 Review Part 2: https://www.dpreview.com/forums/post/65012028
Panasonic Leica 12 – 35mm F2.8 Lens: https://www.dpreview.com/forums/post/67553189
All the best and cheers for now...
