Hello dears,
new to this forum so I'm not sure I'm placing the question in the right place ...
I have to make a 2m x 1m20 print and wonder if the 20Mpx from the R6 is enough.
I also own a 6DII which is 26Mpx so I'm a bit hesitant to go back to this old (but really good) reflex for this specific picture ... but I actually like much more using my R6 for plenty of reasons.
Any advice ? Would 20Mpx be enough for a (very) large print ?
thanks a lot !
The R6 will do fine here. Sure, a higher megapixel camera would be
preferred at this size but you can still get stunning results from it. However, for
best results, you'll need to do some prep work first.
I've found what tends to kill large print "perceived quality" isn't lack of resolution, but visible pixelation when you get closer. Running out of super fine detail is OK as long as the image does so organically (think film like). It's when you get up closer and see square pixels with zero grain that it looks bad IMO. And at this print size, you will see pixels if you get within ±18" of the print.
For me, I've found the trick when you're lacking pure resolution (even a 100MP Medium Format camera is going to be short on res at this size) is to make a digital image look like a film image. This means rather than detail dropping off the cliff into sharp pixels, it does so with softer edges and a bit of grain. Yes, I said
grain. This makes the image print so, so much nicer! Once you reach the end of visibly sharp detail for an output size, a bit of grain is more aesthetically pleasing than blurry, noiseless edges. That just looks "unnatural".
Basically, you're going to need to enlarge, and alot. Getting your image up to 200ppi minimum. So this means about 16,000 x 10,000 for your image size. You'll want something like Gigapixel AI. Everyone has different workflows (it's rarely best to simply just 'go as big as possible'). I'm happy to share my workflow if you're interested.
After you enlarge, you'll want to add some grain. Lots of ways to do this. I use Photoshop and the Camera RAW filter and tweak the grain till I like it.
Long story short, here's a comparison of a native 6000x4000 image and the same one enlarged to about 16,000 x 11,500. Enlarged in Gigapixel then my own workflow in Photoshop, with grain added.
On screen it may look very grainy, but this will print very nicely at 200ppi for a huge print. I'm not saying everyone likes grain, but trust me, it really helps when pushing the limits to the extreme like this. The detail extinction sorta melts into the grain and just look nice when it's on paper. It looks and feels more like a high quality film image rather than a digital file that ran out of resolution for the purpose.
My site:
http://www.gipperich-photography.com
