Hello Nikon people, weird thing happened with my D70...
I got the D70 off someone who used it for Studio use. It had 43k shutter actuations. I got it, and the e-shutter was syncing wrong, before it eventually locked up with the mirror down. I sent it to a repair shop, cancelled the repair, and the camera... somehow miraculously worked again? With none of the artifacts that I had before (black bar on the bottom of the screen indicating some timing issue with the e-shutter and mechanical shutter). I tested at speeds where the e-shutter kicks in, and signs of blooming is present, indicating the sensor can at least gate properly.
I was using my D70 for a walkaround, and got in 70-80 shots before I ran the buffer through. Suddenly, the camera shut off, and locked with the mirror up and shutter closed with little to no explanation, with a classic in-and-out of the battery not doing me any favors.
I get home, pop in a new battery, and the camera fires on with an 'Err' screen on the top LCD which cleared after one shutter actuation. The "photo" that the D70 took came out as a corrupted NEF, and can't be read on both the camera and the PC. Camera seems to operate fine afterwards, but what baffles me is that the battery only needed 10-15 minutes of charging before it was fully juiced. This seems to indicate that (alongside the corrupted NEF and the weird state the mirror was in) the camera shut off on its own for some weird reason.
I'm using a Kingma EN-EL3E battery with a Kingma charger. I don't have access to an original Nikon battery since it came with no battery.
I'm using a Sandisk Extreme 32gb adapted with an off-the-shelf SD to CF adapter.
Any... help?
Any... help?
