yardcoyote
- Messages
- 18,130
- Solutions
- 14
- Reaction score
- 18,310
I am pretty sure by this point that I am going to end up with a Zf eventually, and it's also pretty clear that there's going to be a wait before that happens. So I am trying to learn a few things ahead of time to help me make what I hope are wise lens choices and avoid spending a ton of time and money going down dead ends.
I know I can get the FTZii adapter and use a wide range of F mount SLR and DSLR lenses going back quite a long way. It's my understanding that autofocus lenses with their own internal motors, like the G series, will autofocus normally through the adapter. But autofocus lenses that depended on the motor in the body, (what I think of as "screw drive " lenses since I come from Pentax), like the D series, will not, since the Zf does not have an in body motor.
But what about manual focus? I know the Zf has a lot of interesting MF aids that make it a great choice for use with manual lenses. In particular, there is a focus confirmation thing where the lens can use the camera's AF system to confirm accurate focus by turning the focus box green. I know this works with the "chipped" MF lenses from Voigtlander (and very attractive lenses they are too), but I have also read several places that this system also works with certain F mount lenses through the adapter.
Is this true? Can I use AF F mount lenses in MF mode and get focus confirmation through the Zf's viewfinder? If so, will this work with D series lenses as well? In other words, can I use D series lenses as MF lenses on a Zf? Will the aperture rings work normally? I actually own a 50mm f/1.8 D leftover from another project-- it's quite a nice lens optically and I was keeping it to use on a Df if I ever got one. Is it a candidate for MF project status on a Zf?
What about older, non AF lenses? Is there a generation of MF F mount lenses with electronic connections that will provide the "green box" focus confirmation through the FTZii adapter and also allow me to use the aperture rings normally?
Instagram: @yardcoyote
