Digital Nigel
Luminar Neo's new AI-based GenErase tool does essentially the same job as Affinity's InPaint tool. In both, you paint an area of the image, and it fills it with generated pixels inspired by the surrounding area. Affinity's tool has been around for years, makes no AI claims, and is fast and easy to use. So I thought I'd compare them:
This is the original image, taken at Kjosfossen waterfall on the Flåm Railway in Norway.
Original image — I wanted to removed the concrete reinforcement section in the bottom right
First I tried Neo's GenErase. Despite multiple attempts, i couldn't get it to entirely remove the grey band where it failed:
Neo GenErase. Note the thin grey strip and blurring along the bottom left. I couldn't get rid of this despite numerous attempts.
Then I tried Affinity's InPaint brush:
Affinity InPaint. Much quicker and easier, worked on the first attempt with no failed grey bits.
If you look carefully, you can see where it's duplicated existing areas, so I'd probably do some cloning to cover them, but I've left them here.
Comparing them:
Comparing the original with the twoe generated versions
They're obviously both fake, but I can't decide which is the more natural looking. Which do you prefer?
Comparing them:
