Philip Eihuyar
- Messages
- 1,688
- Solutions
- 3
- Reaction score
- 690
I think there will be less of breaking older machines from hardware and OS upgrades in the future. The real changes can be on the OS side. What I believe the attraction and differences are for PC users and Mac users are that users of PCs like to 'build their own' machine from different venders of third party parts. It gives PC users a sense of independence or freedom of choice . But, also, has real limitations because of the clear speed advantages of Apples' silicone chip integration with memory and application support. Mac now has a clear market advantage for good reason. The strength of Mac hardware is going to be focused on malware threats which are going to be Chip based in manufacture. PC s are not really going to be a good security choice if users can put is pieces from third party venders.The problem is that we don't know what the next architectural change will be in hardware. There will be one, we just don't know when and what. So trying to predict beyond the three macOS generations gets quite risky.Yes, Intel Mac owners are in a different category. But this subthread is about Apple Silicon Macs and how long they are supported. The OP was asking about buying a new Mac that he wanted to use for many years. Also, this line I wrote in my post was not included above:
If I had to guess, the next hardware change is going to be triggered by AI and home changes (which in turn are being triggered by the Vision AR). It might come in communications, though that generally hasn't triggered an architectural change problem that's significant.
That's unlikely, but possible. I want to see what Apple does with the iPhone 16 before I commit to answering that question. The reason has to do with AI/Siri, which is undergoing significant change in R&D. How much of that change is architectural rather than modular will determine the answer.It sounds like what you are saying is that someone could buy an M1 MBA directly from Apple today and then find out that tomorrow there is a new MacOS update that cannot be used on the M1 MBA. Is that correct?
I think you're misreading or misinterpreting what I wrote. At the moment, nothing has happened that would keep the Apple Silicon Macs from continuing to be supported in macOS upgrades. But once you start trying to guess how long your Apple Silicon Mac will still be getting macOS updates, you have a problem: Apple is leading-edge aggressive with tech, and when tech triggers an architectural change, that's the point where support starts getting dropped for the previous architectures.
Apple has another problem now (which the PC makers have had for a long time): upgrade buying is down on Macs. This actually increases the chances that they will make an architectural change, not decrease it.
But if you want to press me on this, I'd say that an M1 Mac probably is going to survive another two or three macOS updates. That's Sonoma+2 or 3. We already know that an M1 can run Sonoma, and Sonoma won't go away with support until late 2026 worst case, so if I'm right, we're talking 28 or 29.
On the downside is the gradual takeover of a kind of visual busyness and clutter of UI design. It does this at the cost of miniaturization of text. I do wish OS designers would take Mac users back to visually simpler times. For instance, when something is downloaded, the progress bar is so small you often spend time to find it. To move a window in Safari or any browser results, more often than not, in clicking the wrong place in the top of window. one cannot just go to top of window and hold down and move it. There was, in past times an obvious place to hold down to move window. These and many other little things take up over a days computer use quite a bit of unnecessary annoying lost time. So, The OS designer side of upgrades has a bit of improvement that should be included that would not break the machine of older macs but would be a positive in users knowing an upgrade as a benefit. The 'everything has to be gray' of Jonney Ives should be reversed back to the original shaded buttons and muti-color Apple icon. Sounds like a small thing but it has always bugged me.
In truth, most of the PC UI it owes to Apple original UI designers. People should remember that.
