F
fred last
Guest
I chose to travel to Albuquerque NM because after researching the weather almanac of all the major US cities along the eclipse path, Albuquerque has the best chance of sunny days.
(All images are JPEGs and cropped)
sun spot
OM-1 + PL 100-400 + Thousand Oaks Solarlite telescope filter (which perfectly fit over the lens). I did a lot of testing before the eclipse and decided on the following settings:
Program mode with ISO set at 1250. Metering mode - full frame, Exposure compensation -2.5EV, AE bracketing 7 levels @ 0.5EV steps to ensure hitting the best exposure. All images taken @ 400mm (800mm FF equivalent) f6.7 - SS varied from about 1/1000 at partial eclipse to about 1/60 at annularity.
I used autofocus because I find it impossible to manually focus with live view. I used full-frame multi-point AF - when I half-press shutter release button (using release cable), one or more green AF points appear. I only shoot the picture when one or more of AF points are at the edge of the sun - this ensures sharp focus on the sun but not necessarily on eg. sun spots.
A lot of effort shooting a hula hoop!
sun spot
