puttin
What are they
In addition to the above, some cameras will not tolerate some types of fluorescent lighting and cause banding in the image. My OM5 is susceptible to this, particularly in some museums and art galleries, so it’s mechanical shutter for those venues.Depending on the sensor readout speed. Otherwise without a global shutter there could be rolling shutter effect and a relatively slower flash synchorized speed too.
For top end models, when they have a fast enough readout speed, no real cons but 100% shutter shock free (not every mirrorless suffers shutter shock) and no wear and tear on m-shutter curtain.
For lower end models, it would show rolling shutter effect, might not support flash (some might but at slower Synchorized speed) and some are limited to slowest 1" shutter speed too.
Some brands will limit e-shutter to silence mode so it could be a pro and con depending on the shooter. However e-shutter is not neccessary completely silence, some brand can add sound effect, e.g. AF confirmation, shutter release etc that can address the silence mode inconvenince.
There is a third shutter: the hybrid Electronic First Curtain Shutter which can address those shortages of e-shutter and m-shutter, but genreally are limit on the fast shutter speed zone. AFAIK some brands will limit EFCS to 1/320" and mine, limits to 1/2000" which is far slower from e-shutter max 1/16000"or m-shutter max 1/8000".
You are a Fujifilm XT user so here is Fuji's take:What are they
The EFCS shutter on my Sony A99ii and the A77ii before that can shoot a maximum of 1/8000 sec. This is true of other cameras with EFCS as well. In other words no difference between full mechanical and EFCS shutter speeds.Depending on the sensor readout speed. Otherwise without a global shutter there could be rolling shutter effect and a relatively slower flash synchorized speed too.
Why do you think that?I also think you will find a slight increase in noise using an electronic shutter over a mechanical one
More noise and less dynamic range have been shown to be a consequence of the electronic shutter in some cameras. Different implementations might have a significant impact or none at all. Read the first post on this page for some details.Why do you think that?I also think you will find a slight increase in noise using an electronic shutter over a mechanical one
Notice he said "will", present tense.I also think you will find a slight increase in noise using an electronic shutter over a mechanical one
That person was talking about early implementations pre Stacked Sensors. His last sentence said, "From what I know of recent sensor designs this is likely a thing of the past (but was real a decade ago)."More noise and less dynamic range have been shown to be a consequence of the electronic shutter in some cameras. Different implementations might have a significant impact or none at all. Read the first post on this page for some details.Why do you think that?
I noticed that as well. I think that often statements are made without consideration of the latest advancements in sensor/camera/lens technology. Of course if one is using or considering buying a camera that is not making use of these advancements then there is some value, but they should be not taken as current.Notice he said "will", present tense.I also think you will find a slight increase in noise using an electronic shutter over a mechanical one
He said '... think you will.' It is an opinion, and a definite possibility, considering the OP didn't specify any camera in his question.Notice he said "will", present tense.I also think you will find a slight increase in noise using an electronic shutter over a mechanical one
Some electronic shutter cameras have this issue and some don't. One person's forum comment doesn't represent everything that's known about a subject, so to think that this can't be an issue with some recent cameras would only be an opinion as well.That person was talking about early implementations pre Stacked Sensors. His last sentence said, "From what I know of recent sensor designs this is likely a thing of the past (but was real a decade ago)."More noise and less dynamic range have been shown to be a consequence of the electronic shutter in some cameras. Different implementations might have a significant impact or none at all. Read the first post on this page for some details.Why do you think that?
Additionally traditional fluorescent tubes are rapidly being replaced by LED based lighting (often compatible with the same fixtures). These seem to be much better behaved... I have never personally experienced banding with electronic shutter in fluorescent lights, but I rarely shoot under fluorescent lighting anyway.
Some LEDs might be better behaved; others are not.Additionally traditional fluorescent tubes are rapidly being replaced by LED based lighting (often compatible with the same fixtures). These seem to be much better behaved... I have never personally experienced banding with electronic shutter in fluorescent lights, but I rarely shoot under fluorescent lighting anyway.
Similar results with my OM-5 at a newly opened art gallery, presumably with LED lighting. Test before committing to electronic shutter indoors..... lesson learned.Some LEDs might be better behaved; others are not.Additionally traditional fluorescent tubes are rapidly being replaced by LED based lighting (often compatible with the same fixtures). These seem to be much better behaved... I have never personally experienced banding with electronic shutter in fluorescent lights, but I rarely shoot under fluorescent lighting anyway.
This is an evenly lit door in my garage, illuminated by LED and shot with electronic shutter:
Another example under the LED fixture in my pantry:
Electronic shutter modes have more post-gain read noise at lower bit depths, if they use lower bit depths for speed's sake. If you have a camera with a 1/30s rolling shutter speed at 12 bits, the rolling shutter speed would drop to 1/7.5s if the camera tried to use 14 bits for e-shutter mode. That would be problematic off-tripod for narrow angles of view, even with a static subject that isn't moving.Some electronic shutters also reduce dynamic range by a stop or two. Though, come to think of it, I have never understood why this might be the case.
Maybe this is supposed to be about e-shutter vs both EFCS and full-mechanical? E-shutters top off at double the shutter-speed on some cameras.The EFCS shutter on my Sony A99ii and the A77ii before that can shoot a maximum of 1/8000 sec. This is true of other cameras with EFCS as well. In other words no difference between full mechanical and EFCS shutter speeds.Depending on the sensor readout speed. Otherwise without a global shutter there could be rolling shutter effect and a relatively slower flash synchorized speed too.
